-   -   New Question!!!Rebuilt Water System all done*Pix* (http://www.hardwarecanucks.com/forum/water-cooling/50199-new-question-rebuilt-water-system-all-done-pix.html)
Soullessone21 January 7, 2012 05:00 PM
New Question is it better to have your push pull setup pull air from outside or push the hot air out of your case? just trying to get my temps a little better:)
So Due to the fact my Crappy Thermaltake Big Water 760i Seized up I had to rebuild my system.
So I went with the following.
System Specs
FX 8150 AMD 8 Core
4x2GB Patriot DDR3 2000
Asus Crosshair V Formula Board
Asus CUII 6970 2GB DDR5
2x120GB Raid Striped OCZ Sata SSD's not sure model just newest and cheap but fast
2TB WD Black Backup drive
N13 Wireless card Asus
thermaltake chaser mk-1 Case
Thermatake 850watt PSU
LG Burner
Cooling system
2x240mm Fans Stock ones
2x120mm Noctua Fans on Rad
2x120mm Ultra Thin fans (found them in my storage and they were never used)
Water Cooling parts
Swiftech MCP350 Pump
EK Dual 120mm Rad setup in push pull
EK Multi inlet/outlet Rez tube
Thermaltake CPU Block*worked great for the last build so stuck with it*
Rasa GPU cooler
Swiftech BGA Memory Ramsinks Cut down to fit around piping
Lots and lots and lots of Thick 3/8 id Tubing
Used very nice Stainless for Polyurethane Airline clamps
System is built and running leak tests for the next few hours.
after that is done I will post how the temps are on here and OC it as much as possible.
But all and all this build is done, my New LGA2011 build starts on the 30th with 2 7970.
So I will either keep this system as a AMD toy and use it while I do the other build or Maybe its time to sell it and put all my money into the intel build.
Thanks and enjoy the pix and advice would be great this is my first water build without a watercooler kit just buying parts and throwing them in.
http://i1213.photobucket.com/albums/.../photo21-1.jpg
http://i1213.photobucket.com/albums/.../photo11-1.jpg
http://i1213.photobucket.com/albums/.../photo12-4.jpg
http://i1213.photobucket.com/albums/.../photo22-4.jpg
http://i1213.photobucket.com/albums/...21/photo31.jpg
http://i1213.photobucket.com/albums/.../photo32-2.jpg
http://i1213.photobucket.com/albums/...21/photo41.jpg
http://i1213.photobucket.com/albums/...21/photo51.jpg
Birk January 7, 2012 05:50 PM
Lookin good :) I've got the same case and my loop is in the mail so i'll do some pics as well. Nice to have these to look at to envision what i've got to work with.
zsamz_ January 7, 2012 05:58 PM
only thing i don't like is the tubing:bleh:
Birk January 7, 2012 06:01 PM
Yea the kit i ordered from Dazmode comes with white tubing too which is a real downer to me so i ordered some UV Blue, I'll save the white for extra or i'm thinking of playing around with some liquid chillers so i could use it with that or something
Soullessone21 January 10, 2012 07:46 PM
BUMPED!!!! new question :)
Birk January 10, 2012 08:23 PM
Pull from outside and exaust out the back of the case
matari January 10, 2012 08:26 PM
Feed your radiator fresh air from the outside. While it's more complicated than that, it should produce lower temps.
Soullessone21 January 10, 2012 09:25 PM
Holy Crap you guys were bang on and now my leg has air conditioning :P
I moved all fans to push pull and moved the other big 240 to the top.
All the rad fans and top fans pull/push into the into the case now CPU and GPU dropped 10C :O from 40 on CPU under load to 27-30 and from 47 on load on GPU to 32-35.
Thanks for the help everyone. now anyone know where to get 2 240mm fans for the front and side :P
