New Loop, Need final comments!
Okay I'm hoping to place my Dazmode order tonight to cool my new system.
System Specs (as far as what matters for the Loop)
i5 2500k
HD 6950 2gb Reference
Thermaltake Chaser MK-1
850watt PSU
Here is what I plan to order if all goes well.
2 x XSPC RASA RAYSTORM KIT FAN - 1650RPM 63CFM 29 dBa $19.98
1 x Raystorm kit level up - Upgrade to D5 Vario $0.00
1 x EX240-D5S XSPC DAZMODE RAYSTORM COMPLETE WATERCOOLING KIT $249.99 Raystorm CPU Block Intel (AMD Braket included) EX240 Dual Thin Performance Radiator Two Fans and Stealth black Grills 5.25" Dual Bay Reservoir Pump Combo DazMode Storm D5 Strong Pump Six Black Crome 7/16 Compression fittings Thermochill Flex 7/16 Tubing (White) Radiator's (optional) External Mounting Hardware K2 Thermal Grease and PSU Jumper
2 x 7/16" - 5/8" - Straight Compression Fitting - Chrome (Silver) $11.98
1 x Aquacomputer aquagrATIx for HD 6970 & 6950 (XT & PRO) $99.99
6 x XSPC 7/16 ID 5/8 OD High Flex Tube 1ft - UV Blue $11.94
$393.88 - Sub-Total:
$29.28 - Canada Post (Regular, 2012-01-18):
$21.16 - 5%GST#89094 6510 RT0001:
$444.32 - Total
