Old January 5, 2012, 04:38 PM
Default Swiftech MCP655 on 3/8 id tubing
Hey Linus,
i was wondering if 3/8 id tubing will fit on Swiftech MCP655
Old January 5, 2012, 04:40 PM
Birk's Avatar
"MOST" water blocks have the same holes G1/4" if im not mistaken. You just get fittings to go from that to whatever tube you work.
Short answer is Yes.
Old January 5, 2012, 05:08 PM
sswilson's Avatar
In this case you're unfortunately mistaken. The MCP655 has fixed 1/2" barbs which cannot be changed out without purchasing an aftermarket add-on.
Old January 5, 2012, 05:25 PM
lowfat's Avatar
1. Boil a pot or kettle w/ water.
2. Fill a cup w/ the water.
3. Soak the end of the 3/8" tubing in the hot water for about a minute. Shake off excess water.
4. Place 3/8" tubing over the fixed 1/2" barb on the MCP655.
It is rather easy to do as long as the water is hot enough.
I've even been able to fit 3/8" tubing over 5/8" fittings (Eheim pump) w/ this method.
Old January 5, 2012, 05:40 PM
Silent_Avenger's Avatar
Sounds like a pain to get off later on if you need to change out tubing or pump.
Main System //// Dedicated Folding PC 1 //// Dedicated Folding PC 2 //// Laptop
Youtube Channel: http://www.youtube.com/DarkDivinityPC
I fold for a cure. Team 213366 and 54196.
Old January 5, 2012, 05:55 PM
Birk's Avatar
oh damn haha. I do have the right idea though don't I? I've been reading up quite a bit on water cooling again before i invest in a loop for my new system.
Old January 5, 2012, 06:22 PM
lowfat's Avatar
I find tubing hard to get off barbs no matter if the tubing was stretched or not.
Old January 5, 2012, 06:33 PM
sswilson's Avatar
Yeah, in many cases the barbs are easy enough to switch out, but in the case of stock Swiftech pumps that doesn't work (their other main pump is a 3/8" fixed barb... ;) ). The DD pump I've got allows for standard barbs to be used which comes in handy if you're looking to use something with an angle.
Old January 5, 2012, 07:12 PM
KaptCrunch's Avatar
note: do not use a 90 on inlet of any pump on outlet is ok
lowfat is correct but use good hose
Old January 6, 2012, 11:34 PM
Zer0's Avatar
My suggestion is to get an aftermarket top so you can screw in the correct sized barb or compression fitting.
[WTB] Swiftech (MCP655)(FOUND) Chromey Buy/Sell & Trade 3 September 18, 2010 12:34 PM
[WTB] Swiftech MCP655 Fudd Rucker Buy/Sell & Trade 8 October 19, 2009 08:02 PM
[WTB] Swiftech MCP655 pump, Dtek Fusion 2, Noctua p12 netforce Buy/Sell & Trade 3 January 13, 2009 06:16 PM
WTB: Swiftech MCP655 miggs78 Buy/Sell & Trade 0 October 7, 2008 02:39 PM
swiftech mcp655 wiring Corpus Masochist Water Cooling 15 September 9, 2007 09:30 PM
