<~----> Swiftech Radbox Weight Limit? - Hardware Canucks
Old January 3, 2012, 02:47 PM
Zer0's Avatar
Default Swiftech Radbox Weight Limit?
I'm currently using a radbox to hold a 2 x 120mm rad (Swiftech MCR220) on my old computer. Anybody using a radbox to hold a 3 x 120mm rad (eg. RX360) with 6 fans? With all the fans, water, and fan grills installed it's probably around 8 pounds. It'll be installed externally in the rear of a Fractal XL case, think it'll hold?
Old January 3, 2012, 03:12 PM
KaptCrunch's Avatar
what size of screws ? #6 grade 2 will support 375 lbs
best use a thick walled spacer to mount eg. metal tube
Old January 3, 2012, 03:16 PM
Zer0's Avatar
Not sure what grade they are. I got them from MDPC-X, black oxide 6-32 threaded 35mm hex screws.
The part I'm worried about is the radbox bracket which is held on by 4 tiny (as in like 2mm long) screws, one on each side.
Where do you get tube spacers like that? I couldn't find any at any of my hardware stores (Home Depot, Rona, Canadian Tire, etc)
Old January 3, 2012, 03:23 PM
KaptCrunch's Avatar
or add a braket to help support those wil hold as long aren't striped
Old January 3, 2012, 04:30 PM
Zer0's Avatar
Guess I'll have to play around with it and see.
Old January 6, 2012, 05:34 PM
Dazmode's Avatar
I used it with triple, but switched to metal brakes later to feel better.
Orange Build: Final Video
HTPC Build: Final Video
Old January 6, 2012, 05:40 PM
sswilson's Avatar
heh... I was thinking that I'd risk it myself, but only with the radbox supporting the middle fan so that 120mm of the rad was raised... ;)
Old January 9, 2012, 09:47 AM
Zer0's Avatar
Update: According to Gabe at Swiftech, the radbox will hold just fine.
Old January 9, 2012, 10:52 AM
KaptCrunch's Avatar
how would he know when he copy and pastes, billA taught him
excrise aka monitor your weight? CTA Off Topic 27 September 5, 2010 10:06 AM
cpu cooler weight limit rob123 Air Cooling 5 March 31, 2010 07:42 AM
Swiftech radbox Dr_BenD_over Water Cooling 5 October 28, 2008 06:16 AM
Wtb: Radbox!!! rai_polo Buy/Sell & Trade 6 October 18, 2008 11:00 AM
cpu cooler weight question in....... rob123 Air Cooling 6 March 22, 2008 08:30 PM
