-   -   1/4in tubing on 3/8 barbs (http://www.hardwarecanucks.com/forum/water-cooling/49893-1-4in-tubing-3-8-barbs.html)
vinsonnguyen December 30, 2011 04:48 PM
hi, i was wondering if it would leak if i put 1/4in tubing on 3/8 barbs or 1/2 barbs
JMCD December 30, 2011 05:32 PM
That'd be very difficult to do, or impossible for the 1/2" barbs. If you're looking for a tight/secure fit look at compression fittings, or use 7/16 ID tubing on 1/2 barbs.
lowfat December 30, 2011 05:52 PM
Or just use 3/8" tubing on 3/8" barbs (or 1/4" tubing on 1/4" barbs_ like it was designed too. I don't think stretching tubing makes it anymore secure.
vinsonnguyen December 30, 2011 06:02 PM
ok thanks
vinsonnguyen December 30, 2011 06:06 PM
i can't seem to find 1/2in 5/8od tubing would you suggest any
JMCD December 30, 2011 06:45 PM
That size would kink very easy. Dazmode has regular 1/2 ID 3/4 OD or 7/16 ID 5/8 OD though.
Buy Liquid Cooling PVC Tube in Canada
vinsonnguyen December 31, 2011 01:56 PM
i going to us a dye bomb on a phobya water would it create algae if i use pvc i am planning on buying a danger den tubing but it is very expensive
