Old December 30, 2011, 11:02 AM
Default Swapping out CPU blocks
I just recently setup my loop on a new system, and I'm still running a single core TDX block, and as expected the temps are TERRIBLE. I'm gonna get a new block soon, but it leaves me the question of how should I swap out the blocks in the most non-intrusive manner to the loop? Thanks!
Old December 30, 2011, 11:06 AM
dandelioneater's Avatar
Your safest bet would be to drain your loop and start again with fresh fluid. You could try clamp off your tubing before and after the inlet/outlet of your block and drop a towel on top of the socket before you remove the tubing from the block. Then replace the block and top off the resevoir. I've done it before, but its a bit messy and awkward, and no matter what you get spillage. So I would say just drain it for the best results.
Old December 30, 2011, 11:23 AM
matari's Avatar
Drain your entire loop, if possible, remove it before disassembling. Not worth any other method. If you plan to remove parts frequenty, you may consider Koolance Quick Disconnect (QDC).
Old December 30, 2011, 11:25 AM
That sounds good. I'm fine with draining, but what I don't like is that my case is particularly cramped, and I'd hate to redo all the tubing.
My PC is a bit like a german car right now, to access the ram, you must first remove the radiator
ugh, my temps is 40C idle with speed step on!
Old December 30, 2011, 01:16 PM
Is that at stock 40C idle, just drain the loop and save yourself the mess trying to switch blocks with liquid still in the tubes unless you have QDCs of course. Won't really have to redo the tubing, just pull out the block and swap them and put it back in you'd have to do the same if you didn't drain it anyways. Wouldn't want water spraying all over the place now.
Old December 30, 2011, 01:43 PM
KaptCrunch's Avatar
2 of these would clamp on tube before WB barb and have towels to catch drops when pull off hose from first barb then cap open barb with a plugged tube to keep viscosity seal of fluid in WB, then do other hose keeping barbs to ceiling
Old December 30, 2011, 04:12 PM
3.0charlie's Avatar
That is sig material...
Just drain the fluid before swapping blocks. It's worthwhile to change the fluid yearly anyway.
Hydro-Quebec is salivating...
Old December 30, 2011, 05:12 PM
lowfat's Avatar
Try remounting the block first. TDX isn't a bad block. We are talking less than 5C compared to modern blocks.
The Crippled God WIP
Queen of Dreams WIP
Big Lian Li
Complete
Forever Alone Complete
Old December 30, 2011, 07:31 PM
But its a single core tdx, not the mc-tdx
Old December 30, 2011, 08:17 PM
drain drain drain. Don't be lazy... lazy kills hardware.
Mah Rig now
Mah Rig before
My stuff for sale.
swapping cases _dangtx_ Troubleshooting 6 December 3, 2010 09:12 PM
Temjin TJ09 Swapping Out 1 Fan.....3 Hrs ?! rjbarker Air Cooling 2 February 5, 2010 07:08 PM
swapping routers lyned Networking 5 May 5, 2009 08:18 AM
Swapping PSU Fan Infiniti Power Supplies 9 January 10, 2009 08:13 PM
Swapping out CPU's - Question rjbarker CPU's and Motherboards 21 November 1, 2008 12:27 PM
