-   -   Installing H100 on Rampage IV Extreme X79 Motherboard (http://www.hardwarecanucks.com/forum/water-cooling/49809-installing-h100-rampage-iv-extreme-x79-motherboard.html)
CrazzzyCannnuk December 27, 2011 08:00 PM
Hi i'm just installing my h100 on an Asus rampage IV extreme motherboard. My question is in linus's video he takes off the stock backplate which is installed out of the box on the back of the motherboard and installed the extra backplate that comes with the motherboard, but he never says why. i'm just wondering why he did that and if it's necessary? here's a link to the video LGA2011 Intel Core i7 CPU Installation Guide H100 Water Cooler Linus Tech Tips - YouTube
Shadowmeph December 27, 2011 08:22 PM
because when you use the original one the H100 won't seat onto the cpu properly. if you use the original back plate and then mount the h100 to the cpu the screws will tighten up tight but there still is play in between both the cpu and the h100 cooler. I hope I explained this properly.
CrazzzyCannnuk December 27, 2011 08:24 PM
So should i install the second backplate that came with my motherboard?
KaptCrunch December 27, 2011 08:40 PM
1 Attachment(s)
after watching seems reviewer didn't ( read manual .pdf ) do home work on intel stand off's, looks manual shows use 2011 stand off
IMHO I'd use the back plate to keep the solder where to be when working temps
do test mount without thremal paste to check clearance using supplied stand offs
KaptCrunch December 27, 2011 08:52 PM
in video looks if was a heat speader on backside of MB
the CROSS yes if not supplied use the corsair Cross
http://t2.gstatic.com/images?q=tbn:A...mtDKyy3Tpo7rvA
CrazzzyCannnuk December 27, 2011 09:22 PM
YES this is the second backplate (heatspreader) i received but it was not installed on the motherboard, There is a different one installed currently on the board when i received it. it was a little bit bigger and it filled in the holes around that heat spreader in the picture. but i'm wondering should i install that head spreader in the picture or stay with my current one that came with the board?
CrazzzyCannnuk December 27, 2011 09:25 PM
Heres a website that gives a step by step pictures on how to install the second heatspreader on the back of the motherboard, should i do this? and why??? ASUS Rampage IV Extreme
KaptCrunch December 27, 2011 09:29 PM
what MB we talking ? 2 heatspeader supplied with MB ? use one that threads hold WB if not use Cross
http://limages.vr-zone.net/body/13795/P1020150.jpg.jpeg
yes thats ok it will supercede cross that back plate
CrazzzyCannnuk December 27, 2011 09:48 PM
i think i figured it out. i was following the steps in the video when i now realize that his motherboard has a frontplate rather than a backplate, where as the asus rampage IV extreme doesn't have the same "frontplate" so i just followed the steps of corsair and my motherboard and its fine thanks anyways.:biggrin:
SugarJ December 27, 2011 10:43 PM
The Rampage IV Extreme has 2 backplates because it will fit both LGA1366 and LGA2011 coolers.
