Old December 23, 2011, 11:51 AM
Birk's Avatar
Default Thinking of getting this kit.
EK Complete Watercooling kit H3O HF 240EN (Dual Rad)EK Complete Watercooling kit H3O HF 240EN (Dual Rad) EK Complete Watercooling kit H3O HF EN 240 (Dual Rad) [H3O-240HF-EN] - $259.99 : DazMode, The Best Canadian PC Watercooling and Modding Store!
Is this the best option aside from fully custom? EK seems to be a well respected name but it's been awhile since I've messed with water cooling.
Old December 23, 2011, 11:59 AM
lowfat's Avatar
It is a good kit. The pump is a bit on the weaker side but it can easily be replaced down the road if you ever get the upgrade bug. It will be sufficient for this though.
The Crippled God WIP
Queen of Dreams WIP
Big Lian Li
Complete
Forever Alone Complete
Old December 23, 2011, 12:07 PM
Birk's Avatar
I do plan to upgrade parts for sure. Off the bat i forsee angled fittings, a new rez cause that one seems tiny to me? and a new pump as I'll probably add a GPU block.
Old December 23, 2011, 06:12 PM
Birk's Avatar
Hmm actually that does look good.
Old December 23, 2011, 06:27 PM
AkG's Avatar
AkG AkG is offline
Hardware Canucks Reviewer
That kit jd is talking about is VERY sweet. I have one here on a testbed (ex240 ddc 3.25 version). The only issue I have with it is..its an acrylic res and does NOT come with a kill coil or the parts to add a reservoir fill tube. Other than its VERY sweeeet.
Old December 24, 2011, 06:52 PM
Birk's Avatar
Okay so I'm going to grab the Raystorm kit that JD suggested. Would that pump be powerful enough if I added a GPU block? Also which block would I want to get for a 6970?
Old December 24, 2011, 07:45 PM
JD JD is offline
It would be more than powerful enough.
You can go here to see what block would fit your card: CoolingConfigurator.com
Old December 25, 2011, 05:07 PM
raystorm rules. I love this block.
Mah Rig now
Mah Rig before
My stuff for sale.
Thinking of a new SFF F@H PC ilya New Builds 7 November 19, 2010 02:17 PM
thinking 480 sli rogue woopa New Builds 4 July 24, 2010 02:44 PM
thinking about WC lcdguy Water Cooling 4 July 1, 2010 09:17 AM
Thinking out of the box mgrisoli Cases 25 August 22, 2009 03:26 PM
Not sure what I was thinking but...... kruzn4evr Display Units 42 March 9, 2009 06:48 PM
