Old December 20, 2011, 03:36 PM
Soullessone21's Avatar
Default Converting say a Coolit CPU cooler to GPU Cooler
So I want to have some fun on my holidays and want to know if its possible to convert a Coolit ALC water system to a GPU cooler for my 6970 CUII as I hate having it aircooled where everything else in my system is water cooled.
Thanks for Listening Chiiiildren (damn I need to stop playing fallout)
Old December 20, 2011, 04:02 PM
It's been done before, the tricky part is getting an elegant mounting solution. Keep in mind most of the blocks on these kits (aside from the newer Coolit made Corsair models) are fairly tall and will take up 3 expansion slots.
Old December 20, 2011, 04:23 PM
thanks so much just wanted to know if it has been done and dont worry the CUII takes up 3 slots already haha
Old December 24, 2011, 06:58 PM
Can you post pics if you do it? would be cool to see how it looks and performs...
Old December 24, 2011, 08:13 PM
Done it to my gtx460, performance gain over stock was mediocre. The heat load was a bit too much i think.
Coolit Omni GPU cooler belgolas Water Cooling 19 November 13, 2010 09:23 PM
CoolIT Freezone CPU Cooler Gav Water Cooling 12 March 12, 2007 04:56 PM
