Old December 20, 2011, 09:52 AM
Astaroth's Avatar
Default Rear Radiator /w LGA2011 board
Are there clearance issues with running a single 120 or 140 rear radiator with the new RAM layout for LGA2011 motherboards?
Old December 20, 2011, 10:06 AM
Eldonko's Avatar
Hardware Canucks Reviewer
Not sure anyone can answer that without knowing which case and which board.
Old December 20, 2011, 10:30 AM
KaptCrunch's Avatar
shouldn't be a issue unless mini-ITX case
looks OP thinking of corsair Hxxx series cooler
Old December 20, 2011, 11:03 AM
dandelioneater's Avatar
one could always get the h100 and top mount it in an appropriate case and potentially avoid any such issues at the rear exhaust area,
Old December 20, 2011, 01:47 PM
Astaroth's Avatar
There's a level of standardization in respect to the rear exhaust being situated above/beside (pending the orientation as you look at it) the IO ports. With very few exceptions. If the RAM is too tall or the slots too close to the IO, there won't be enough clearance for the rad. The distance from IO first RAM slot would be a great stat to include in all LGA2011 board reviews, or even from manufacturer... heh.
Actually it's if I were to add an additional Radiator to my loop in that spot, and the consequences if I went LGA2011 at a later date.
panasonic rear projection tv help kyle_L Off Topic 0 May 27, 2011 10:17 PM
z68 or LGA2011? Epimetheus New Builds 5 February 28, 2011 12:57 AM
2.1 system + 2 rear speakers? jcmaz Audio 4 June 22, 2009 02:35 AM
Is rear exhaust fan really needed? aviduser Cases 18 March 27, 2009 11:49 AM
Rear Channel on Realtek HD? sswilson Audio 8 July 25, 2007 01:07 PM
