<~----> Need advice for fan hookups.... - Hardware Canucks
Old December 18, 2011, 03:12 PM
BOOG1964's Avatar
Default Need advice for fan hookups....
Hello kind sirs I need a spot of advice on where to hook up all my fans. I do have a watercooled system but the HAF X case looks great with LED fans so Im tossing em in for the good looks. Here is the plan and I could use some help on where to hook up all the fans. I have a G1 Guerrilla mb with a cpu fan header a system fan header and 3 fan headers I have 1 230 mm intake front and 1 200mm intake side 140mm exhaust rear, 2x 200mm exhaust top, 120mm gpu shroud fan and 2x 120mm 240mm radiator fans. If yall would be king enough to lend me some suggestions it would help tremendously thank you.
Old December 18, 2011, 03:28 PM
KaptCrunch's Avatar
can use a fan controlier bay an control sepprately
just pay attention to watts of fans an keep it less the controlier rating when gang joining on rad
Old December 18, 2011, 04:57 PM
BOOG1964's Avatar
LOL I guess I should have mentioned I will eventually get a fan controller but till I get one how should I hook em all up???
Old December 18, 2011, 05:07 PM
Adzsask's Avatar
These
Cables to Go 4IN 3-PIN Fan Power Y-CABLE - CABLES TO GO - 27391
Or these
Works Molex 4 Pin to 3 Pin Male Fan Power Adapter Cable - Works - CB-3M4M
I have used both without a problem.
Old December 18, 2011, 05:09 PM
stoanee's Avatar
Something like this:
Fractal Design PCI-MOUNTED Fan Power Splitter - Converts One 4PIN Molex to 16 Connectors - Fractal Design - 5321185
heatware
Old December 18, 2011, 05:53 PM
BOOG1964's Avatar
So the fan headers on my mb are not used that much then???
Old December 18, 2011, 06:23 PM
KaptCrunch's Avatar
for most MB fan header is 6 watt max load
Old December 18, 2011, 06:25 PM
BOOG1964's Avatar
so dont hook more than 2 up to each fan header to be safe???
Old December 18, 2011, 06:45 PM
AmuseMe's Avatar
I cut and splice all of my fans on my rads into one three pin and plug it into one header on my fan controller
Need some advice HiTi New Builds 4 January 9, 2011 02:45 PM
gpu advice CTA Video Cards 23 December 29, 2010 01:44 PM
Fan advice please! Peanutmc Air Cooling 1 September 27, 2010 09:30 AM
Need advice on new GPU? bushwickbill Video Cards 10 March 10, 2010 03:59 AM
Need some advice... JD Water Cooling 29 May 4, 2009 06:21 PM
