Old December 19, 2011, 10:07 PM
Slaughter's Avatar
I do know a few people who have had issues with Crossfire on it's own. Try running a single card to see how it performs?
Old December 19, 2011, 10:56 PM
- Your RS360 could also do with an upgrade, being the slimmer version its not enough to cool two GPUs and a CPU unless you are running you fans at max rpm and even then the fin density of the RS360 isn't that amazing.
- Your pump's flow rate is also lacking for all the components you have, because its max potential is 522 Litre per hour. If you have three blocks you need at least 650-700 Litre per hour and if you are using any 90 or 45 degree fittings at least 750 to have a decent flow rate.
That should explain the 10 C heat issues for the most part.
Single Loop or Dual Loop? Pump enough for single? MattC Water Cooling 5 May 31, 2011 07:19 PM
I may add a rad or a second loop botat29 Water Cooling 6 April 3, 2011 07:36 PM
Do I have everything I need for WC loop? ADay2Long Water Cooling 15 August 6, 2010 09:34 PM
Another loop order, single/dual loop thread... turtletrax Water Cooling 8 July 28, 2010 08:40 PM
My Soon-To-Be loop Kopi Water Cooling 5 October 23, 2007 12:49 PM
