Old December 12, 2011, 10:32 PM
Default Loop Questions
Hiya,
WC Noob Wondering if i could get some feedback. I am currently planning my loop; currently i have :
swiftech 360 rad
swiftech 240 rad
rasa raystorm CPU block
dual bay res
EK HF universal GPU block (placing order for)(to be used on a sapphire 6950 1 gb )
Dazmode strong D5 (also ordering)(hope its the correct pump for me)
Im planning to go 360>CPU>240>GPU>Res>Pump but tubing will crisscross back and forth, i've read that minimal tubing length is best. So, now considering 360>CPU>GPU>240>Res>Pump. But wont there be a greater cooling effect if the water going to the GPU is cooled first by the 240 rad?
Thanks a bunch mates!
Old December 12, 2011, 11:06 PM
lowfat's Avatar
If you are getting the D5 strong you should buy the 24V Koolance CTR-SPD24 pump controller. Will allow you to have a much stronger pump if it is ever needed.
As for loop order it really doesn't matter much. As long as you have the reservoir before (or at a higher height) the pump you'll be ok. It really doesn't have any real affect on temperatures.
The Crippled God WIP
Queen of Dreams WIP
Big Lian Li
Complete
Forever Alone Complete
Old December 12, 2011, 11:58 PM
Thanks Lowfat, Will keep that in mind, but would increasing the volt to 24v make it so much louder and would it shorten it's life span?
Old December 13, 2011, 09:07 AM
lowfat's Avatar
The D5 Strong is designed to run @ 24V so it shouldn't affect pump life much.
Queen of Dreams WIP
Big Lian Li
Complete
Single Loop or Dual Loop? Pump enough for single? MattC Water Cooling 5 May 31, 2011 07:19 PM
X2O 200 + Loop Questions HOTDOGS Water Cooling 11 April 6, 2011 05:33 PM
Another loop order, single/dual loop thread... turtletrax Water Cooling 8 July 28, 2010 08:40 PM
The Loop - General Questions AmuseMe Water Cooling 18 October 12, 2009 06:04 PM
Soups loop questions thread. Supergrover Water Cooling 6 November 8, 2008 08:14 AM
