  #21 (permalink)
Old December 27, 2011, 07:08 AM
ah i missed that somewhere? Thanks Crunch...
fukin monster than thing hehe!
My stuff for sale.
Mah Rig
  #22 (permalink)
Old December 27, 2011, 07:22 AM
KaptCrunch's Avatar
lian li V series
just figured by case depth
  #23 (permalink)
Old December 27, 2011, 08:05 AM
mattlef's Avatar
Cody,
Looking at the legnth, do you have two vertical 1/4 threads on each side or is there one vertical and one horizontal?
The reason I'm asking is because it looks like there would be little to no room for routing of the tube once installed.
I'm very intersted to see how you plan installing it in the system. Very innovative :D
Personally I love that you took this project on, and I cant wait to see your results.
My Rig:
Motivate TJ07
Check out my Build log!!!
Motivation: Sponsored by Galaxy
Upcoming Changes/Upgrades:
Check the build-log for more
  #24 (permalink)
Old December 27, 2011, 08:29 AM
lowfat's Avatar
Originally Posted by KaptCrunch View Post
lian li V series
Except that is a TJ07 not a Lian Li.
  #25 (permalink)
Old December 27, 2011, 08:38 AM
"Quote This..."
What you should be looking for is fans with a high static pressure rating. That is a measure of how good they push against restricted flow.
Nice work!
Black belt in CAPS LOCK.
  #26 (permalink)
Old December 27, 2011, 09:11 AM
KaptCrunch's Avatar
looks close but where's your razed start button 565 mm is 22.244 inches
  #27 (permalink)
Old December 27, 2011, 09:14 AM
AmuseMe's Avatar
Any progress on the shroud?
EDIT: It is hard to tell from your pics, but are you using flat or round tubing in the radiator?
No progress on the shroud yet. I haven't worked on it since my last post here. Most shops here where closed down last Friday til' Tuesday, so I wouldn't be able to get it done any ways. As for the tubes, they are 3/4 in flat staggered tubes - they don't all line up. Like this:
Could you take some photos of it from further back? Maybe put a 20 dollar bill beside it so I can get some idea of how big it is? Dun want artsy fartsy pics just the Facts Man!
This is an experiment I plan on doing myself sometime.
thx.
ps Dazmode had some high cfm 120mm fans on sale for half price recently.
I'll take some more when I get back to the shop tomorrow - that's where it is. I might use some of those HIGH rpm GT fans and just put them on a fan controller. I also have a Coolit Freezone that I will be using - to chill the water. So as long as I get some fans that can actually get through this thing, I won't worry about "how much" air gets through :)
Originally Posted by mattlef View Post
Cody,
Ones vertical, ones horizontal You'll just have to wait and see, to see what I do!
Nice work!
I think I know what fans I'll be using - maybe. I just mentioned that a Coolit Freezone will be used in conjunction with this rad - so water temperature should be fine.
Thank you everyone for checking this out so far and leaving comments - it is greatly appretiated!
Next up - and 'L' shaped radiator those goes vertical in the 5 1/4 drive bays, and then horizontal.
It's a TJ07. I put automotive body filler in ALL the exterior holes (power, LEDs etc.) I'll be relocating them up into the face plate area.
  #28 (permalink)
Old December 27, 2011, 09:57 AM
mattlef's Avatar
I think I already know now lol. And Kudos, thats ballsy. If i'm right, this is gonna look amazing.
My Rig:
Motivate TJ07
  #29 (permalink)
Old December 27, 2011, 10:28 AM
lowfat's Avatar
It definitely is a TJ07. You can tell by the size of the case + the fact that it has a raised lip on the sides on the front of the case.
The Lian Li also has mesh holes on the front and on the bottom of the case. TJ07 doesn't.
  #30 (permalink)
Old December 27, 2011, 11:43 AM
KaptCrunch's Avatar
maybe so but alu start button is throwing it off
Computer's built severity New Builds 2 December 3, 2010 06:55 PM
OK I built it, now what? LaughingCrow Guides & How-to's 16 April 24, 2010 12:56 PM
First Self-Built Rig - $800-850 CanadianONE New Builds 8 January 18, 2010 04:46 PM
Need help with my custom built PC icepizza CPU's and Motherboards 1 June 29, 2009 12:19 PM
AMD new built Chris New Builds 45 April 25, 2009 07:26 AM
