<~----> GAH! Algae in my loop! - Hardware Canucks
Old December 10, 2011, 06:18 PM
Default GAH! Algae in my loop!
Well it's been 3 weeks since my loop has been setup, and algae has already made loop a home for itself. I am running 30/70 ethylene glycol and distilled water mix, and its still blooming.
I'm waiting on a couple parts to come in before I flush the loop, in the mean time can anyone give me some tips?
Old December 10, 2011, 06:35 PM
lowfat's Avatar
Why do you think there is algae?
Old December 10, 2011, 07:13 PM
There are green algae growing on the walls of the tubes, looks identical to the algae that grows on the side of the aquarium.
Old December 10, 2011, 07:22 PM
lowfat's Avatar
What about your reservoir? Is it green as well?
Old December 10, 2011, 09:02 PM
Nope, seems to be fine, I'm going to double check
Old December 10, 2011, 09:25 PM
lowfat's Avatar
You used cheap tubing more than likely. It is plasiticizer. Replace it w/ a good tubing like Primoclear LRT.
KaptCrunch's Avatar
loose the EG and go with PG the white bottle is less toxic, by the way why using 30/70 mix ?
mixed metal loop? rad outside in the snow?
Old December 10, 2011, 09:27 PM
Well, I needed some toxicity in the water to prevent algae growth, but clearly it wasn't enough.
If it is indeed because of cheap tubing and doesn't affect cooling performance then I am good with it
Old December 10, 2011, 09:48 PM
SugarJ's Avatar
If it's in your loops, it's gumming up your blocks too. Change it out.
Old December 10, 2011, 09:59 PM
KaptCrunch's Avatar
geoc mite be cheap anti-freeze geling up
Single Loop or Dual Loop? Pump enough for single? MattC Water Cooling 5 May 31, 2011 07:19 PM
Another loop order, single/dual loop thread... turtletrax Water Cooling 8 July 28, 2010 08:40 PM
Anti-Bacteria / Anti-Algae products in Canada? demonsblood Water Cooling 15 July 5, 2010 11:19 PM
Loop help Lpfan4ever Water Cooling 12 September 22, 2009 06:22 PM
Got algae!! biff Water Cooling 12 September 30, 2008 07:17 PM
