Old December 10, 2011, 11:07 PM
Yup, i just double checked, the res is completely clean, it's only the tubes that are cloudy with a layer this stuff. So I assume it's a tubing or coolant problem then? Aw man, this means I have to completely redo the loop.
Old December 10, 2011, 11:15 PM
It sounds like the coolant to me. Honestly I'd just run distilled water with a silver coil or 4 silver barbs. I use the silver barbs and after 9 months there wasn't anything growing in there :P
The only reason I would use coolant like yours is if you are mixing metals.
Old December 10, 2011, 11:16 PM
So silver barbs are a equivalent substitute to kill coils? I learned something new! Off to ncix i go!
Old December 10, 2011, 11:38 PM
lowfat's Avatar
Sounds like tubing to me still. Are you by chance using the Rasa kit?
The Crippled God WIP
Queen of Dreams WIP
Big Lian Li
Complete
Forever Alone Complete
Old December 10, 2011, 11:40 PM
AkG's Avatar
AkG AkG is offline
Hardware Canucks Reviewer
IMHO...nothing beats a kill coil. With "silver" barbs you have to watch out as most are nothing by silver color. Stick a kill coil in your res...use distilled water...and replace the tubes with new...AND flush your parts out VERY..VERY well to make sure no gunk is in there....then in say 2mths check again.
YMMV
plus why not use daz's shop? IMHO daz > ncix when it comes to wc gear here in canuckistan. :>
Old December 10, 2011, 11:43 PM
To lowfat: Nope I'm using the tubes I found at home depot. I read online about them, people said they were fine for PC watercooling if I can get past the fact that they kink easily.
To AkG: I found that daz has more selection and better prices, but I live a couple mins from an NCIX store so it's more convenient plus I save on shipping.
Old December 11, 2011, 01:47 AM
algae will NOT grow in glycol so it can't be algae.
Mah Rig now
Mah Rig before
My stuff for sale.
Old December 11, 2011, 02:02 AM
YMMV
The only ones I know of re the Bitspower "True silver" ones, which I've used for a year and a half. Not sure about other ones, are there knock offs? Silver coil is highly recommended though.
  #19 (permalink)
Old December 11, 2011, 03:43 AM
chubaka's Avatar
im with lowfat on this one, if the res is clear (and i assume the coolant should be as well) then its plasticizer. Plasticizer can appear greenish as in this pic taken from xtremesystems
  #20 (permalink)
Old December 11, 2011, 03:58 AM
bissa's Avatar
the pipes in that picture looks like copper oxidization. I guess that could be what's happening with OP if his pipes looks like that.
Single Loop or Dual Loop? Pump enough for single? MattC Water Cooling 5 May 31, 2011 07:19 PM
Another loop order, single/dual loop thread... turtletrax Water Cooling 8 July 28, 2010 08:40 PM
Anti-Bacteria / Anti-Algae products in Canada? demonsblood Water Cooling 15 July 5, 2010 11:19 PM
Loop help Lpfan4ever Water Cooling 12 September 22, 2009 06:22 PM
Got algae!! biff Water Cooling 12 September 30, 2008 07:17 PM
