Gonna be getting a triple rad setup.
My system specs are in the thing located to the right.
EK-KIT H3O - Supreme HF 360 EN
EK-KIT H3O - Supreme HF 360 EN - Kits - Kits & Watercooling Cases
EK-VGA Supreme HF - EN(universal) / ram sinks
EK-VGA Supreme HF - EN (Nickel) - VGA Supreme HF - Universal VGA waterblocks - VGA Blocks - Blocks
The only option I could think of is to have the rad mounted on top of the case with the fans on the inside mounted to the ceiling pushing air up.
This is the layout I was thinking of:
(If I do go with this layout I would be cutting out the top using a template)
I am new to water cooling but have been building computers for years now so I'm not to worried about putting it together.
I just need some tips on placement of things. The case is mid sized so there isn't tons of room but I think this layout would work.
Do you guys see any potential problems with my layout plan, especially the radiator?
Also if this layout will work, do you have any tips for certain hardware to make things go smoother?
