  #51 (permalink)
Old December 20, 2012, 08:49 PM
Just with a power drill and a bit that fit, you just need to drill out the head of the rivet
  #52 (permalink)
Old December 20, 2012, 09:10 PM
Wow, that was quick. Thanks. If you're interested check out my build here:
The beginnings:
THE HACKINBEAST !!! EVGA SR-2 w/2 x X5690's - GeekBench: 36,583 !!! - Page 2
Finished product:
PunkNugget's Mod - THE HACKINBEAST ! - MacMod of the Month - InsanelyMac Forum
  #53 (permalink)
Old December 20, 2012, 09:13 PM
Thanks for the quick help. By the way, did you have to modify anything else on the HD case other than cutting off the two extra HD bays. I'd like to see where you put in your screws. If that possible to see some pics of where the screws were placed. Again, thanks... :)
  #54 (permalink)
Old December 20, 2012, 09:45 PM
I'll see if I can get a couple pics for you tomorrow. The only other thing is removing the fans assembly from the bottom. I also thing it's easier just to get a 2 5.25 bay to 3 3.5 bay adapter rather than reattaching the original cage as it loses it's rigidness.
  #55 (permalink)
Old December 20, 2012, 10:21 PM
What would you suggest then for a bay holder? Thanks... :)
  #56 (permalink)
Old December 21, 2012, 08:12 AM
The beginnings:
Finished product:
  #57 (permalink)
Old December 24, 2012, 06:04 PM
Hey Jibz, Just letting you know that I took out the Hot Swappable rack out like you said (by drilling out the rivets). I also did a few other things to make some improvements that I will post later.
Corsair H70 in a Raven RV02 Talnoy Water Cooling 5 December 28, 2010 02:29 PM
[FS] Silversone Raven RV02 + extra's Cowboy Buy/Sell & Trade 54 February 5, 2010 01:32 PM
Micro projector PC build idea RangerBill New Builds 2 January 19, 2010 11:19 AM
Silverstone Raven RV02 vagnaar Case Mods, Worklog & Gallery 2 November 11, 2009 08:52 PM
shooting for a build, any idea's? Scutum_Deus New Builds 2 September 24, 2008 11:28 PM
