<~----> FT02/RV02 3x180 build idea - Page 4 - Hardware Canucks
  #31 (permalink)
Old December 18, 2011, 08:28 PM
Alright got a revision closing in to final revision if someone would like to double check it and give me feedback it would be much appreciated.
Part list:
Swifttech Apogee HD white acetal top
2x EK 580gtx+ full cover blocks nickel acetal
magicool 560 rad 3x180
swifttech micro res
laing ddc 3.25 pump
EK SLI link in parallel
3 45 degree 3/8ID 1/2OD compression fittings
2 straight compression fittings
1 male to male g 1/4" rotary extender (res to pump)
1 bitspower L block
pearl white 3/8id 1/2od primoflex tubing
2 male koolance QDC VL3M compression
2 female koolance QDC VL3M compression
Silver Kill coil
distilled water
Revision log:
moved to 3/8id 1/2od tubing from 1/2id tubing as fitting availability favors it and I think 1/2id may look too bulky.
Added QDC to my plan
Made best use of angled compression fittings instead of adapters and straight fittings.
plan to mount the res ontop the pump with a male-male rotary extender
  #32 (permalink)
Old December 20, 2011, 07:42 PM
Jibz...looks great man
  #33 (permalink)
Old December 20, 2011, 08:36 PM
Looks good. Also have you considered 7/16ID 5/8 OD tubing? It's not as fat but still has about the same flow as 1/2ID. It's not as common and may not have the colour you want, but worth taking a look at.
  #34 (permalink)
Old December 20, 2011, 08:43 PM
I'm mainly trying to figure out tubing by fitting availability lol.
  #35 (permalink)
Old December 20, 2011, 08:45 PM
lowfat's Avatar
3/8ID 1/2OD kind of sucks. Tubing that has a wall thickness of 1/16" kinks really easily.
  #36 (permalink)
Old December 20, 2011, 08:54 PM
My idea is to try to have no bend in my tubing at all, just all straight lines using angled adapters.
  #37 (permalink)
Old December 22, 2011, 03:31 PM
Got my rad today, a 3x120 for comparison
  #38 (permalink)
Old December 22, 2011, 03:55 PM
Looking good Jibz, can't wait to see how it turns out
  #39 (permalink)
Old December 22, 2011, 09:00 PM
Dont you just love it!..LOL..I did the same thing when mine showed up...I just kept putting other stuff up against it to see the size
  #40 (permalink)
Old December 22, 2011, 10:06 PM
it makes me think I might want a d5 instead of a ddc.
Corsair H70 in a Raven RV02 Talnoy Water Cooling 5 December 28, 2010 02:29 PM
[FS] Silversone Raven RV02 + extra's Cowboy Buy/Sell & Trade 54 February 5, 2010 01:32 PM
Micro projector PC build idea RangerBill New Builds 2 January 19, 2010 11:19 AM
Silverstone Raven RV02 vagnaar Case Mods, Worklog & Gallery 2 November 11, 2009 08:52 PM
shooting for a build, any idea's? Scutum_Deus New Builds 2 September 24, 2008 11:28 PM
