Old March 6, 2008, 06:29 PM
Scart's Avatar
Alright well now that the case is out of the way I can move onto other matters.
So what is the best choice for coolant?
I wouldn't mind paying a little extra for non-conductive coolant, though I'm not sure which brand to go for. And how much more effective is distilled water than such coolants? If I did use water, I think I might use 7/16 tubing over 1/2 fittings just to make sure it's sealed.
After that I just need to figure out which mobo, so I'll pop over there now.
Old March 6, 2008, 08:44 PM
llama_egg's Avatar
Truthfully, I say just use distilled water + addictive, much cheaper and as long as your careful you don't need to worry about frying your parts in the first place.
Old March 7, 2008, 02:56 AM
Misoprostol
Guest
Posts: n/a
Feser One has just become available in Canada. I haven't tried it yet, but I've heard good things, and this colour looks sexy: http://www.ncix.com/products/index.p...re=Feser%20One
Old March 7, 2008, 10:12 AM
llama_egg's Avatar
Hehe, so true, I'm picking up a couple bottles just to see the stuff in person. The black looks amazing, and I'm tempted to check out the orange out of curiosity. Also thinking of picking up a couple of those Primochill dye bombs to see how they turn out.
Got to withhold myself...or I'll have an order of like $200 worth of coolants which I would end up reviewing. <_<
Old March 7, 2008, 10:22 AM
biff's Avatar
I've read (can't remember source) that even the non-conductive fluids do become slightly conductive over time as it will pick up ions from the copper in the system. Don't forget water is non-conductive as well if it's pure enough, it only becomes conductive when stuff is dissolved in it. I'm sure though that the "non-conductive" fluids have a much reduced tendency to pick up the ions.
Also water is non as destructive as rumors make it out to be. I had a system running a 15% glycol/DI water mix that the pump blew up on and blasted water in a 4 foot radius. After the coolant evaporated some of my stuff didn't work. I washed off the residue with a solvent and that brought everything back to life. Even my new HDD was sitting in a puddle of coolant and it still works and that was about 3 years ago. On my new rig i'm just going to try DI with a touch of algaecide.
Q6600 @ 3.83GHz w/ D-Tek Fusion
Asus P5Q-PRO
2x 2GB PC8000 Mushkin Redlines @ 1020MHz w/5-5-5-12 timings
EVGA GTX 280 (SC?)
OCZ Gamer Xtreme 600W PSU
Cooler Master Cosmos on water
Old March 7, 2008, 11:01 AM
Cptn Vortex's Avatar
I want the Black stuff! I am also going to re-do my loop. Found a sweet hardware store with all sorts of 1/2 Brass fittings and L's an T's, as well as some crazy thick tubing! From what I can tell the tubing is 1/2, however the measurements listed are metric, time to get the calculator out! But it is thick! Like, 4-5mm thick walls!
The Vortex H20
MSI Z77A-GD65
Intel i7 3770K @ 4.6GHZ 1.28v
Galaxy GTX 680 @ 1241MHZ
8GB Mushkin Blackline 1600MHZ 9-9-9-24 1.5v
Asus Xonar Essence STX
OCZ Z-Series GOLD 850W
2 x 128GB Corsair Force GT SATA3 SSD RAID0 :)
Acheiva Shimian Q270 Lite 2560x1440
Benq W500 Pojector.
Watercooling:
EK Supreme HF, EK FC GTX 680 Block, MCR320+Gelid Silent 12 Push/Pull, DD Pump, EK Multioption 100ml Res, EK Coolstream XT 220 RAD Gelid Wings Push/Pull.
Old March 7, 2008, 03:00 PM
Scart's Avatar
Anyone know how the Feaser One compares to the Fluid XP+? I'm digging the blood red, but its pretty pricey. Primochill also has some stuff. I still would like to find something that compares all the major coolants as well as distilled water.
Old March 7, 2008, 03:08 PM
llama_egg's Avatar
I've been hearing amazing things about Feaser One, apparently it gives better temps then Fluid XP.
  #19 (permalink)
Old March 8, 2008, 12:29 AM
Scart's Avatar
I think I'm gunna go with the feser one uv black.
It should look pretty awesome with blue coils in the aurora 570.
  #20 (permalink)
Old March 9, 2008, 06:05 AM
theAlien's Avatar
hi all my first post here..........
here is something to read up on how they compare
bit-tech.net | Watercooling Fluid Shootout - Introduction, FluidXP+
Alan
Radiator? nick_black Water Cooling 8 February 12, 2008 07:24 PM
WTB: triple radiator ( 120 x 360) elninio Buy/Sell & Trade 0 January 22, 2008 10:52 AM
p35 question Jim CPU's and Motherboards 6 August 28, 2007 02:44 PM
Tips to clean radiator eagle_ Water Cooling 2 August 22, 2007 07:28 AM
Top mount radiator - what would I need? JayDee Water Cooling 22 July 17, 2007 06:21 AM
