Originally Posted by ilya *Most* of the bubbles are *usually* bled out by the manufacturer, but with proper mounting they should eventually be trapped at the top of the radiator.
As for the reservoir, refer to 7/8th grade chemistry: water can absorb a large amount of heat before it evaporates. (which it won't be doing a lot in this case) The benefits of additional thermal capacity (from more water) in a closed loop system are quite significant. |
But the benefit of the extra water is just temporary? After all, the CPU will continue to dump heat into the water until it reaches the equivalence point between the rad's thermal dissipation capacity and the CPU heat dump.
