Old November 29, 2011, 10:59 AM
Cool, thanks for the link! Oh ya another question about tubing, for cutting the tubs what do you recommend. I can see using scissors as non-ideal for it wouldn't be that straight and probably rather kinked at the end. Exacto Knife the best?
Old November 29, 2011, 11:11 AM
Shadowmeph's Avatar
aslong as what you are using is sharp enough pretty much anything is good for cutting water cooling tubing.
Folder :
ASUS KGPE-D16 Dual Socket G34, 8x2GB kingston1333MHz DDR3, 2x 6i28 CPUs 2x NH-U9DO A3
Old November 29, 2011, 12:15 PM
yycraven's Avatar
PrimoFlex Pro LRT Black ID 7/16
this is the good stuff. :)
ASRock Extreme 3,2500K,NH-D14,Patriot G2 16GB ,WD 750GB,640GB Sata ,2 GTX 470 SLi Thermaltake toughpower XT850W,Tech Station. V243H,2253LW LCD
heatware
Old November 29, 2011, 03:52 PM
Stanley knife :)
My stuff for sale.
Mah Rig
Old November 29, 2011, 04:25 PM
lowfat's Avatar
Originally Posted by Slaughter View Post
Hey man! Nice to see you here ;)
NCIX.com - Canada's Premier Computer Store - Online PC Discount Store, Buy Computer Accessories
I use Feser and I've been quite happy with it. Seems to be fairly flexible while maintaining it's shape. :)
Their 3/8" tubing walls aren't thick enough. It kinks too easily. But if you like big bulky tubing then their 1/2" stuff ain't bad.
I use a tubing cutter. It was ~ $10 @ Performance PC's and always having a nice clean cut makes it worth it to me.
Old November 29, 2011, 05:13 PM
Ya I was thinking there was an actual tube cutter meant for hosing. Will have to stop by the hardware store then.
[WTB] 1/2" ID tubing / Cheap radiator Fudd Rucker Buy/Sell & Trade 0 January 30, 2010 09:58 AM
[FS] 780i, 2x2gb ddr2 1066, q9550 cheap! cheap! cheap! kyle_L Buy/Sell & Trade 16 November 24, 2009 07:05 AM
Tubing, tubing... what to choose? Dazmode Water Cooling 16 June 23, 2009 02:32 PM
