Old November 25, 2011, 07:27 PM
Default Mr. Daz.
Looking to purchase these things for my 3/8 id loop.
I have all the compression fittings already just making sure it's gonna work before I purchase meaning I'm reading the specs right. I replace the original laing top with the xspc dual resi one so i can use any g1/4 fittings i want? I don't know much about these xspc d5 resi's. I know for my setup the bay drives is where I have extra space.
DazMode STORM D5 STRONG 8-24V Pump DazMode STORM D5 STRONG 8-24V Pump [D5T STRONG] - $67.99 : DazMode, The Best Canadian PC Watercooling and Modding Store!
XSPC Dual 5.25 Reservoir for One Laing D5 Single Loop XSPC Dual 5.25” Reservoir for One Laing D5 Single Loop [XSPC-DBSL-1D5] - $58.99 : DazMode, The Best Canadian PC Watercooling and Modding Store!
I have a couple other things on the list however these are the 2 main parts I need to rebuild my loop.
Thanks!!
Also are you getting more of these anytime soon?
RayStorm CPU WaterBlock (AMD) [RAYSTORM-A] - $69.99 : DazMode, The Best Canadian PC Watercooling and Modding Store!
Old November 27, 2011, 08:27 PM
Dazmode's Avatar
Yes, you can put any fittings you like.
Raystorms are coming shortly. 5-7 days.
Orange Build: Final Video
HTPC Build: Final Video
Old November 28, 2011, 09:01 AM
Ok I ordered one off your site. I can wait though.
My stuff for sale.
Mah Rig
Old November 29, 2011, 06:59 PM
Restricted Poster
Where are you located Daz? I'd like to know where I'd be buying from, I can't find it on your site. I might spend $1000 with you. A coupon would be nice. :)
Old November 29, 2011, 07:09 PM
Dazmode's Avatar
Company is based in Oakville since 2001.
You will get a lot of rewards points on large order. Always nice to have them for next order, which is inevitably will come.
Restricted Poster
So you're not going to take the bait? Hmmm... well... I am still sorting out some things, deciding on video cards. When I do place my order hopefully you'll remember me and you can double check it for compatibility. Thank you.
Old November 29, 2011, 09:11 PM
Dazmode's Avatar
I don't know it all, and can only speak for the parts I use myself. So, I might be not much help with compatibility confirmation. Try to find somebody who use your exact GPU model already.
It also doesn't matter for me if you spend $10 or $1000, I prefer to treat everybody well and with the same respect regardless dollar value behind. I will appreciate your support in any form you decide it to be and that works best for you.
Old November 30, 2011, 06:29 AM
DAZ is extremely competative and very fair pricing in my opinion. That and he's Canadian ffs! When a busy guy is gonna take the time to reply to my questions; even when they are lame duck questions, he gets my business. Period.
He ain't charging extra like swiftech etc for a pump.
My stuff for sale.
Mah Rig
