Old November 21, 2011, 05:37 AM
Default dual pump question again
Someone posted a dual pump top for the ddc pumps and of course xspc makes a dual resi setup for the d5's. Those setups are serial and from what I gather you'll only get about a 50% increase. What I'm wondering is wouldn't dual pumps work better in a manifold situation?
You take 2 pumps run them into a manifold and then into a single line loop and back into either a manifold or resi with dual outlets. I dunno. It's something i've debated trying and haven't seen anyone here do anything like that. Seems to me you'd get better flow rates and pressure. It's how we plumb our houses so it kinda makes sense in a WC situation too.
cheers
Old November 24, 2011, 07:19 AM
guess i'll have to experiment when I get a chance.
Old November 29, 2011, 06:33 PM
A good read for you.
Multi Pump Setups – Parallel vs. Series « martinsliquidlab.org
I'm going dual pump in serie after asking questions and reading that link above.
Just go in serie, no need for a manifold. Do it KISS!!
Old November 29, 2011, 07:39 PM
thanks for the link mang!
My stuff for sale.
Mah Rig
Old November 29, 2011, 08:14 PM
dustin1706's Avatar
Grab one of these dual tops from EK. They make them for series or parallel.
EK-D5 Dual TOP G1/4 - Black Acetal - Pumps Accessories - Pumps & Accessories
Rig1 in "My System Specs"
Rig2: Q6600, P5DN-D, GTX650, 4GB HyperX, LG BD drive, TT armor case, ek supreme HF, 655 pump, XP
Dell XPS17 - i7 2820QM, 8GB ram, 1920x1080, BluRay, GT555m 3GB, 240gb Neutron GTX, 640GB Seagate, Win7 64
Server - i5 3450, Asus P8Z77-I Deluxe, 4GB DDR3, LSI MegaRAID 9240-8I, OCZ Vertex 4 120GB, 2x SG Barracuda 3TB(RAID1), 2x WD green 2TB(RAID1), Fractal Design Array R2, WHS 2011
Old November 29, 2011, 08:15 PM
No problem. If you ever do that manifold, let us know the results.
Old November 30, 2011, 06:54 AM
Couple major problems with that review / test this guy did.
1/ he absolutely needs to be using a manifold this is basic plumbing. Y adapters don't work at all for this test if it did we'd see them in housing all the time. This doesn't work.
2/ he needs to reduce the output lines to increase the pressure this means from the pump he uses 1/2 inch tubing and reduces to 3/8's as outputs from the manifold. There has to be a reduction to increase the pressure which he talks about.
3/ the goal is to have dual loops one resi with one rad via the manifolds. I could cool the ram on a seperate loop off the manifold and cool vid/cpu on it's own loop. I'm thinking it's just gonna have to be dual loops in the end. ;-)
Guess I'll have to test it for myself at some point.
My stuff for sale.
Mah Rig
Old November 30, 2011, 07:51 AM
KaptCrunch's Avatar
would need this kind of manifold to regulate each WB so all are same flow before apply to MB
Old November 30, 2011, 03:14 PM
I agree with your drawing but i wanna play with the pump setup a little. :-)
Lose some serious flow rate off the manifold the trick is adusting for it.
My stuff for sale.
Mah Rig
Old December 3, 2011, 09:42 PM
BMaverick's Avatar
Lightbulb
If you visited Martin's site, did your read up on the pumps? He did a nice job on the pumps I have for others. Putting two in series would make a sweet loop and have minimal heat dump into the loop and run cooler.
Support Your Local Sheriff - At high noon
My Heatware http://www.heatware.com/eval.php?id=63611
The pump maverick
Pump orientation question ADay2Long Water Cooling 10 December 13, 2010 11:31 AM
Where to buy XSPC 5.25 Bay Dual Res, Dual DDC Pump Kartner Water Cooling 11 July 1, 2010 09:14 AM
loop and or pump question gomer Water Cooling 5 June 8, 2010 06:48 PM
xspc dual bay dual ddc pump resivour gomer Water Cooling 12 May 10, 2010 04:00 PM
Pump Question lcdguy Water Cooling 10 February 19, 2008 07:58 PM
