Old November 20, 2011, 11:54 AM
Default Linus Intel RTS2011LC
Hey, Linus will you do a benchmarking test with the Intel RTS2011LC to see how good it is to the other water cooling option out there.
please and thank you
Old November 20, 2011, 11:57 AM
AkG's Avatar
AkG AkG is offline
Hardware Canucks Reviewer
IIRC Intel is using ASETEK as their oem. Single thick, single height 120mm rad means it should perform similar to the older first gen Corsair H units or Asetek LCLC 120...and get its arse handed to it by a Corsair H80, Antec Kuhler 920, and Corsair H100.
Old November 20, 2011, 07:41 PM
im sure it performs the same as a kuhler 620, same pump and rad
Old November 20, 2011, 11:26 PM
Linus's Avatar
It's a thick rad so it'll perform better than the 620.
Should be very similar to H70 or any other single thick rad pre-built liquid cooling unit in terms of performance.
Please note: I am not here to provide official NCIX support on these forums.
For faster (and official) NCIX service please contact our customer care team at www.NCIX.com (Canada) or www.NCIXUS.com (USA)
Heatware: http://heatware.com/eval.php?id=25647
Old November 21, 2011, 10:42 AM
Trial Member
I wonder if the fan is any good, or if it's a loud unit like most of the fans Corsair goes with for their water based coolers. :/
Old November 21, 2011, 11:22 AM
Soultribunal's Avatar
Bah, I always replace the fans vs stock.
-ST
www.realhardwarereviews.com
Old November 22, 2011, 02:05 AM
Linus's Avatar
It seems decent and it certainly LOOKS baller, but I can't really speak of its exact performance.
Old December 21, 2011, 05:30 PM
You cant go wrong with the corsair h100, ive had 2 builds using them and they are: simple to install, look cool, keep the processor pretty cool, and are not that expensive(this kinda depends on your defenition of expensive). The only downside is that it wont fit every case
I always go with Noctua :P
Tags
intel , rts2011lc , water cooling
Hey Linus! Intel or amd? PcWizTech New Builds 19 November 15, 2011 12:29 AM
Linus Q&A enaberif Suggestions & Feedback 45 October 2, 2011 09:13 PM
Intel 875K and ASUS new OVERCLOCK bios gaget ( Linus tech Tips ) ZZLEE Overclocking, Tweaking and Benchmarking 3 May 31, 2010 04:19 PM
