Old November 17, 2011, 01:22 AM
CTA's Avatar
CTA CTA is offline
Default water in the reservoir (part 2)
i switched dual mcp ek top to single ek top with new ek resx 150 tube...
so i watched the res carefully... i still cant figure where the water is going... two week ago, 1/2" of the water disappeared, i checked every parts for water leaking after swapped the parts...
4 days ago, i poured more water into the reservoir and, now i have no idea where 1/4" water is going... i still dont see mirco-bubbles in the reservoir anymore...
so any clues? is there any air in the radiators? (both is vertical and fittings are bottom)
my watercooling configuration is rad1 > pump/res > rad2 > cpu > gpu1 > gpu2
Old November 17, 2011, 12:30 PM
KaptCrunch's Avatar
any pic of the whole set-up, yes mostly the rad aren't burp'ed yet
Old November 17, 2011, 11:43 PM
CTA's Avatar
CTA CTA is offline
most recent picture that i post is...
i dont have quality to picture the present watercooling system...
similar to desgin except dual mcp... first customize case with gen3 i7 system
still work in progress tho (just too lazy to finish sheet for bottom, rear, top and side...)
Old November 18, 2011, 07:00 AM
matari's Avatar
Either your loop is still bleeding or another one of those reservoir is leaking.
Old November 18, 2011, 07:18 AM
KaptCrunch's Avatar
in pic i no see the rez, best way to bleed is have rads face lay down on table use books to support case if rads aren't surcured good
than remove rez/s/ so that is @ highest point of loop an level (above case) use towels to cover case and wrap towel around rez so when filling not to spill
only have pump running and NO POWER TO MB or hardware, can use a spare PSU to power pump only by jumping pin on atx connector
Old November 18, 2011, 10:18 AM
CTA's Avatar
CTA CTA is offline
yes no res in the old picture... lets me picture the present... almost similar...
matari, there is no water leaking anywhere... ;\
Old November 18, 2011, 10:35 AM
KaptCrunch's Avatar
shoot pic of the case side (narrow/long frame opening) where would get rad thin side in left side of snap shot
Old November 18, 2011, 05:30 PM
CTA's Avatar
CTA CTA is offline
just check at my wip thread ;p
Old November 18, 2011, 11:18 PM
matari's Avatar
Honestly you will more than likely not see the leak until it's too late. The rubber o-ring failed on several of my units. Just make sure your loop is bleed properly, and if the water continues to drop it's more than likely the reservoir.
Old November 19, 2011, 06:59 AM
KaptCrunch's Avatar
why can't show real good pic of the rez in CURRENT set-up
or state is swiftcheeze rez with D5 pump or ek rez with ddc355
are the rads serial or parrelle circuit?
id go this set-up below for rez location (D5) will give a better chance keeping air out of loop
if using ek rez remove from pump top, place higher than rads
[WTB] 5.25in Bay Reservoir chibi_man Buy/Sell & Trade 0 November 1, 2010 10:23 AM
Going under water for the first time, part 2: moving to a new home chrisk Water Cooling 88 October 26, 2010 12:54 PM
my reservoir hatabilly0204 Water Cooling 10 April 28, 2010 06:44 PM
[WTB] Single 5.25" Bay Water reservoir Justin Cider Buy/Sell & Trade 7 July 22, 2009 02:58 PM
Reservoir noise matsta31 Water Cooling 17 January 26, 2009 07:28 PM
