Old November 19, 2011, 04:55 PM
CTA's Avatar
CTA CTA is offline
okay i will re-everything... but funny i should see water on my paper towel.. or sheet that protect psu...
well sorry i dont have digital camera... i hope you can guess... so i am wrong...
here is a diagram...
btw do the reservior have to be TOP of the everything? i thought it doesnt matter as long as the tube should be shortest as possible...
Old November 19, 2011, 06:09 PM
Keywork's Avatar
Reservoir should always be above your pump. Allows gravity to feed your pump and minimizes the chance of your pump running dry.
Old November 19, 2011, 11:41 PM
CTA's Avatar
CTA CTA is offline
so my res+pump configure is correct?
Old November 20, 2011, 10:18 AM
are you tapping the air out of the rads?
Old November 21, 2011, 09:39 AM
CTA's Avatar
CTA CTA is offline
how? just shake the radiator?
Old November 21, 2011, 09:54 AM
Your rad inlets are at the bottom.. so I'm gonna say you've got lots of air in them.
Your gonna have to tilt, tip, tap, shake those suckers to get the air out.
Old November 21, 2011, 10:01 AM
Yup, agreed. One of my rads is mounted on my case that way and it takes quite a few weeks for all of the air to be worked out. Tilting it around and such and helps, mine also has a screw hole up top so I can bleed some of the air out that way too.
Turn the pump off and see if you can hear water sloshing around at the top of the rad.
Old November 21, 2011, 08:28 PM
I normally tip mine so the out flow is highest and tap out the air by hitting the side of it. Frankly I think all rads should have a bleeder valve on them its annoying.
[WTB] 5.25in Bay Reservoir chibi_man Buy/Sell & Trade 0 November 1, 2010 10:23 AM
Going under water for the first time, part 2: moving to a new home chrisk Water Cooling 88 October 26, 2010 12:54 PM
my reservoir hatabilly0204 Water Cooling 10 April 28, 2010 06:44 PM
[WTB] Single 5.25" Bay Water reservoir Justin Cider Buy/Sell & Trade 7 July 22, 2009 02:58 PM
Reservoir noise matsta31 Water Cooling 17 January 26, 2009 07:28 PM
