So I currently have:
EVGA P55 SLI
i5 760
2 x XFX 6870's
2 x Arctic Cooling Accelero Twin Turbo Pro
Corsair 600D
Corsair H70
I'm using the 200mm fans that came with the case as well as the fans that came with the H70. I was pretty close to just slapping on the mesh side 600t door with 4 fans and calling it a day but it already sounds like a f14 jet is in full flight while I'm playing games and its pretty loud at idle too.
I figure I can get 50 bucks for the twin turbo pro's with a new set of heatsinks and maybe another 40 from the H70.
Now, with that said...I can't spend any more than $500. From what I've read and seen online, I've pieced together what I think might be a decent setup. For me, it isnt so much to overclock to hell and back or get insanely cool temps, but to have a decently clean setup with ALOT less noise.
DAZmode Rasa STORM RS240 D5 Complete WaterCooling Kit:
Rasa Black (Acetal) CPU Waterblock
DazMode STORM D5 Strong Pump
XSPC Dual bay Reservoir for single Laing D5 pump
RS240 Radiator
120mm Fan x2
2 Meters of Clear 7/16" Hose
G1/4" to 1/2" barbs x6
I would also get:
2 x Watercool Heatkiller FC 6870 block
Another XSPC RS240 Rad
Random barbs and connectors (compression fittings are too expensive)
I was thinking of taking out the top 200mm mounting 1 of the rads on the inside top rad spot and cutting the grille a bit to get some better airflow. Push or pull only though due to lack of space. I was also thinking of ousting the front 200 fan and only using 1 HD cage. That would hopefully leave enough space to mount the other RS240 up there with a single 120mm fan too.
1. Are 2 RS240's going to work alright?
2. Do I have enough pumping power for that loop?
3. Any fatal flaws in the system that I should know about?
Thanks for the help guys
