Old November 16, 2011, 12:51 AM
Default Water cooling Coolermaster HAF X
Hello
what water cooling radiator would be the best that would fit in the top of the coolermaster HAF X case
I was looking at the Magicool Slim Profile 3x140 mm radiator or the
Black Ice GTS Gen Two Stealth 420 high performance radiator
I will be cooling the i7 2600k processor or the i7 2700k processor
as well as 2 Evga GTX 580 graphics cards possibly 3 depending on if i need it.
EVGA X79 FTW mother board
please give advice on any of these componants
Thanks
Old November 18, 2011, 11:57 PM
The general idea is to have a 1x120 "unit" of radiator per major part. CPU + 2 GPUs require 3 "units" so anything larger than a 360.
The radiator depends if you want a high or low fin density. High fin density rads require more powerful fans with good static pressure to see the benefit of lower temperatures (over low fin density rads), but it comes with a cost of noise. Low fin density rads perform well at certain fan RPM ranges (generally around 600 - 2000rpm depending on the radiator). At higher rpm, they are less effective, but overall they will be quieter. You have to figure out what is more important to you, performance or quietness.
Looking at 140mm sized radiators is good. If you decide to use 120mm fans, you will require an adapter which will act as a shroud and remove the "dead zone" behind the fan and have more uniform cooling across the rad. You can also opt for 140mm fans too. The flexibility is there.
Old November 25, 2011, 02:45 PM
definatly performance i just want to make sure it will fit in my case
Old November 26, 2011, 09:42 AM
shabba100's Avatar
i had the same question when i was building my pc also, with that case you have no problem i have a EK H360 triple rad fit no problem and install was nuder a hour you can also see what my pc in my album. hope it help.
Old November 26, 2011, 06:36 PM
I don't know if you have noticed but the cpu's that you are planning to get doesn't work with the motherboard you are getting.. =/
Old November 26, 2011, 07:55 PM
EVGA X79 and a 2600k -2700k dont go together
you goin p67-z68 or 2011?
if you goin 2011 you gonna need 2 rads
i'd go for the 140x3
maximus IV extreme @ 5.1 1.41v
evga e760 +920 4.8 water5.0+ on phase linx stable
gtx285 tri-sli
dfi ut-p35 lt
e8600@4.6 1.38v
too much ram
Old November 27, 2011, 12:26 AM
i have changed the motherboard to the asus Rampage extreme
i forgot to add it to the post sorry
Old December 11, 2011, 02:34 AM
any thoughts on the motherboard
Tags
advice , coolermaster , haf x , help with parts , water cooling
Proposed Water Cooling System for my Coolermaster HAF X case kendrab Water Cooling 9 November 9, 2010 08:18 AM
New To Water Cooling mjbdc07 Water Cooling 10 August 31, 2010 05:25 AM
New to water cooling; need help bkh2 New Builds 31 July 25, 2009 08:02 PM
Sapphire Radeon HD4850 with water cooling system from coolermaster? CarMar33 Video Cards 6 March 27, 2009 11:46 AM
WWT: Coolermaster 590 case + Swiftech water loop for HD3870 b1lk1 Buy/Sell & Trade 4 May 24, 2008 07:41 AM
