Old November 14, 2011, 02:45 AM
Default Antec Kuhler H20 620 question
Hi Folks,
Am just wondering if this cooler would be able to fit in properly with this Motherboard
NCIX.com - Buy ASUS P8H67-M PRO/CSM REV3.0 H67 mATX LGA1155 2PCI-E16 2PCI HDMI DVI Sandy Bridge B3 Motherboard - ASUS - P8H67-M PRO/CSM REV 3.0 - in Canada
Thing is, I'm a bit worried about the distance between the CPU and Memory, would there be enough space?
Also, what other all-in-one water cooling system would able to fit on it.
Oh Case is Antec 300.
Thank You
Old November 14, 2011, 07:42 AM
dandelioneater's Avatar
I'm sure it would fit fine. The pre-filled water cooling systems don't really come close to the memory modules so you don't have to worry about having issues. Also check out the coolers from corsair: H60, H100
Old November 14, 2011, 08:28 AM
KaptCrunch's Avatar
tight fit but works
Old November 14, 2011, 08:40 AM
you could even rotate the pump/block even more either way to bring the tubes around tighter so they don't come close to the dimms.
Old November 14, 2011, 11:30 AM
Ok Thanks guys. Will be doing it Later...:D
FT02 with kuhler 920 orientation?? willhurt69 New Builds 7 January 8, 2013 12:18 PM
Thermaltake Level 10 GT and Antec Kuhler 920 perfect fit narkfestmojo Water Cooling 13 November 9, 2012 02:45 PM
Antec Kuhler 920 temps willhurt69 New Builds 7 January 7, 2012 06:59 AM
Antec Kuhler 620 vs Corsair H60 Thread slippy Water Cooling 5 March 11, 2011 08:04 AM
Antec 900 question krajee Cases 2 February 12, 2011 09:17 PM
