Old November 12, 2011, 06:33 PM
Default Ghetto H50 Cooling on GTX570
Got the idea from here: Blog - Using a Corsair Hydro Series
had no screws, so I used zipties
UPDATE: Bought screws and nuts for better mounting pressure, dropped 8 degrees, now 52-53 degrees MAX at 1.088v
Old November 12, 2011, 07:13 PM
lowfat's Avatar
Wow. Just wow. I've used zipties back in the day to mount waterblocks. But I can't say I've ever seen anyone use a piece of plywood. But if it works, then that is pretty awesome.
The Crippled God WIP
Queen of Dreams WIP
Big Lian Li
Complete
Forever Alone Complete
EmptyMellon's Avatar
Awesome. :)
"All animals are equal, but some animals are more equal than others." - G. Orwell, Animal Farm
Old November 12, 2011, 07:22 PM
Wow that's pretty cool. Good job!
Old November 12, 2011, 07:40 PM
KaptCrunch's Avatar
kudus but replace cover so that ram and vregs get cooled as intended, cut as needed to fit with your dremel
Old November 12, 2011, 07:43 PM
The vrms and ram chips are cooled by the stock plate and theres some airflow from the fan, plate just gets warm under full load
Old November 12, 2011, 07:57 PM
dandelioneater's Avatar
the vrms/ram should be ok with the unisink. Nice work.
Old November 12, 2011, 07:58 PM
KaptCrunch's Avatar
Default active cooling
heat = resistance
try a mock-up fan cover out of GF pantihose cardboard
run 2 benchmarks "cover vs naked"
Old November 12, 2011, 11:46 PM
I just found out the pny gtx580 with asetek liquid cooling is pretty much the same as what I have done
Old November 13, 2011, 09:50 AM
seeing as you are going ghetto and all, and ram/vregs "should" have active cooling, why not get a slightly large piece of ply, and mount a 120mm fan onto the one end of it and have the h50 cooling the core on the other, this way here you will get better cooling for both sides of it?
OCZ ZS 750 for GTX570 SLI? badwolfbri Power Supplies 5 November 11, 2011 08:21 PM
Ghetto rig jobs Jake_HT Off Topic 7 October 17, 2010 01:56 PM
WIP: my ghetto HTPC/Gaming rig Bao HTPC Systems & Software 4 September 8, 2010 06:45 AM
Idea: Ghetto Watercooling arekieh Case Mods, Worklog & Gallery 13 April 21, 2009 09:08 PM
ghetto w/c idea (may not be original) donimo Water Cooling 32 February 14, 2009 11:17 AM
