Old November 12, 2011, 05:28 PM
Default H100 HELP NEEDED!
i mounted the backplate today and found that it would rattle, it was not sitting snug?
is this a common issue?
i found some of these out in the MTB swag and let the modding begin!!
JP
Old November 12, 2011, 06:14 PM
KaptCrunch's Avatar
take a pic of the air space between bracket and PCB
opps did you cut the round nylon washer to fit under nut ?
if so the washer goes on the other side of nut
movie installing
Old November 13, 2011, 11:30 AM
Default RE: WASHER MOD...
the vid is NOT GOOD.
the washer is installed in the correct posittion see the white nylon square.
if the washer was added to the washer side of the backplate it would suspend the backplate off the CPU-mobo metal plate no??...and that would stress the MOBO area not the reinforced metal plate area...
with the stock setup the t-nut was protruding through the MOBO and the stud bottomed out on the nut and causes the ratlle. now the t-nut is below the surface of the MOBO and everything is snugged up.
JP
Old November 14, 2011, 08:20 AM
KaptCrunch's Avatar
currect you want the studs to float through MB with backplate touching metal reinforcement when cpu torqued down
Venomous X or H100? Drumroll Air Cooling 14 April 9, 2012 01:18 PM
Corsair H100 mardig88 Water Cooling 2 November 16, 2011 01:56 PM
H100 install Mod... jef.paas New Builds 0 October 31, 2011 05:10 PM
H100 & Ultra Kaze eXtacy Water Cooling 5 October 4, 2011 09:30 PM
H80 or H100 Reviews? PerryC Water Cooling 40 August 21, 2011 07:57 AM
