Old November 5, 2011, 10:38 AM
JG23's Avatar
Default Best Water Cooled Case For Workstation 1-2 GPU Max
This is my current parts build:
I7-2700k CPU
Asus Maximus IV LGA 1155 Z68
G Skill Ripjaws X Series 16 GB DDR3 2133
Crucial M4 256gb (Main) 2 x 1TB 7200RPM WD Drives (Storage)
1 x Quadro 5000 GPU
Silver stone 1500 W PSU
I was looking at the SilverStone TJ11 case but it seems quite like overkill since im only gonna have 2 GPU's
plz help me with any suggestions
Old November 5, 2011, 10:43 AM
mattlef's Avatar
The TJ07, 800D or even yes, the TJ11 will probably be your best bets for quality and cooling potential.
The TJ11 can handle two 480 rads internally, where the TJ07 and 800D(with some minor modding) can house a 480 and 240 rads internally.
Pricewise, 800D might be the better of the three.... but the TJ07 is just a beautiful case.
CC-HotSpot Host
YouTube Instagram Twitter
Old November 5, 2011, 10:50 AM
JG23's Avatar
I got you, but basically it comes down to if i have the cash why not dish it out for the tj11
Old November 5, 2011, 03:36 PM
AmuseMe's Avatar
CaseLabs will be be a greater pleasure than that TJ11.
The TJ11 has a bunch of plastic slapped onto it... YUCK!
Old November 5, 2011, 06:35 PM
Liu Kang's Avatar
Budget?
If you are only cooling the CPU and 2 GPUs, you can get away with a triple rad with a push/pull fan config. I'd look at Corsair, Lian-Li, Mountain Mods, Caselabs and Silverstone.
If your budget is high, I'd highly recommend a case that can handle additional rads.
LK
WORK KANG: Silverstone SG03 | EVGA x58 Micro w/ 920 @ 4.2Ghz | Sapphire 5970 | 12GB Dominator DDR3-2000 | 240GB Revodrive X2 | SilverStone ST650F
MINI KANG: BitFenix Prodigy | Asus P8Z77i Deluxe mITX w/ 2600K @ 4.5Ghz | EVGA GTX 680 2GB | 8GB Vengeance DDR3-1866 | 2x Intel 160GB SSD | Corsair AX650
KANGZILLA: Custom MM Ascension | SR-2 | 2x X5650 | 2x SilverStone ST1000F | 2x Intel 160GB SSD | 15x 120mm rads | Under construction...
Old November 5, 2011, 08:01 PM
supaflyx3's Avatar
I would say a MM UFO case, or a TJ07.
Old November 5, 2011, 08:12 PM
lowfat's Avatar
What is your budget?
The Crippled God WIP
Queen of Dreams WIP
Big Lian Li
Complete
Forever Alone Complete
Old November 6, 2011, 09:21 AM
Dazmode's Avatar
If you don't care about windowed panel and hot-swap HDDs, 700D is cheap alternative to 800D. HAF another cheap case. Anything else is totally overpriced IMHO.
Also I think somebody is selling cube case in Buy-Sell section.
Orange Build: Final Video
HTPC Build: Final Video
Level 10 GT water cooled HiTi Water Cooling 4 September 23, 2011 04:58 PM
Water-cooled folding rig chrisk Water Cooling 17 December 26, 2009 11:05 AM
[FS] FS:2x EVGA GTX260 SC|4GB OCZ Reaper DDR3 PC3-1600|SunBeam Water cooled Plexi UV Case. MarcusFoX Buy/Sell & Trade 9 October 22, 2009 11:07 AM
[FS] FS: i7 920 D0 EVGA GTX280 & SunBeam Water cooled Plexi UV Case. MarcusFoX Buy/Sell & Trade 21 October 8, 2009 07:34 AM
Water Cooled Case Gallery! cyberspyder Water Cooling 5 September 19, 2007 12:11 PM
