Old November 1, 2011, 12:05 PM
Pabz0r545's Avatar
Ok Thanks! I am about ready to start ordering my parts. I think I have everything selected quite well. I would like to order from in Canada so I will be getting most everything from Dazmode.
Any recommendations on any parts. Ones to specifically shoot for or one's specifically not to get? Thanks.
Does anyone have any input regarding drive bay reservoirs vs those cylindrical ones? I like the look and price of the cylindrical ones but I really really like the space efficiency of the drive bay reservoirs.
Old November 1, 2011, 02:43 PM
Dazmode's Avatar
You nailed it. That is the dilemma everybody have to deal with. I like cylindrical reservoirs a little betetr, but mounting can be pain...
Orange Build: Final Video
HTPC Build: Final Video
Old November 1, 2011, 03:53 PM
Pabz0r545's Avatar
Why do you like the cylindrical ones better? Is it because of the ease of maintenance/fillin/draining? Or simply aesthetics? Or price? Or all of the above haha.
Old November 1, 2011, 04:00 PM
Dazmode's Avatar
Easy to bleed, fill, add liquid. I also like how it glows inside next to mobo, and it doesn't look taht bad when liquid level drops, but i don't have time for maintenance procedre....
Old November 3, 2011, 04:38 PM
Amarthfea's Avatar
after dealing with my first bay res, if at all possible I WILL NEVER GET ONE AGAIN.
don't get me wrong, it has nothing to do with quality, or efficiency or looks. that all sold me on the bay res, especially ones with pumps built in. on the other hand the 18 hour painful learning experience of trying to bleed the sucker, makes me feel like I die a little inside each time I think about it.
just my 2 cents
~Elysium, I behold your beauty...
Old November 3, 2011, 04:45 PM
Pabz0r545's Avatar
LOL 18 hour bleeding learning experience?!?@?! Sorry but that makes me laugh. Why in the world did it take you 18 hours? And what is bleeding? getting all the air out? of the system?
I am just very limited for space. If it buy a bay res I will have room for <<fan<<shroud<<radiator(up to 50mm)<<shroud<<fan type of setup. If I go with a tube reservoir it will take away room from that setup. However I could possibly mount the tube/pump at the rear of the powersupply if it is a short one.
[FS] Closed tabasko Buy/Sell & Trade 6 October 20, 2011 10:34 AM
120.1 Custom Loop vs Corsair H70 PriceMatch Water Cooling 16 December 26, 2010 05:31 PM
Another loop order, single/dual loop thread... turtletrax Water Cooling 8 July 28, 2010 08:40 PM
Help me decide thanks trayton CPU's and Motherboards 2 March 15, 2009 09:51 AM
