Old February 25, 2008, 09:12 AM
kirk_d's Avatar
Default Tec water chiller using Apogee gt's
I gotta an 80 watt pelt and want to sandwich it in between two Apogee gt waterblocks
and incorporate the cold side into my cpu loop.
Already have a spare power supply, pump and rad for the hot side
With some insulation around the cold block,and a proper mount, kryotesc calculator says i'll be getting temps around -25 on the cold side.
So my question is how do you think the delrin, acetal top and fittings that are used in the gt, hold up against sub zero temps?
Is there another block I might consider that would be better suited?
Old February 25, 2008, 12:36 PM
biff's Avatar
Every attempt I've read of making a pelt chiller resulted in less than desirable results. I'm not trying to take the wind out of your sales but just wanted to let you know what you're up against.
There's a new member on board named NoL that seems to really know his stuff, maybe you should PM him. Either way report back with your findings. There's something to be learned in any experiment.
Q6600 @ 3.83GHz w/ D-Tek Fusion
Asus P5Q-PRO
2x 2GB PC8000 Mushkin Redlines @ 1020MHz w/5-5-5-12 timings
EVGA GTX 280 (SC?)
OCZ Gamer Xtreme 600W PSU
Cooler Master Cosmos on water
Bowing the Apogee GT Cptn Vortex Guides & How-to's 10 April 29, 2008 04:57 AM
Swiftech APOGEE Drive JD Water Cooling 14 August 16, 2007 10:35 PM
AC Water Chiller project sizerkozak CPU's and Motherboards 27 March 13, 2007 06:26 AM
