Old October 15, 2011, 11:52 AM
CTA's Avatar
CTA CTA is offline
Default quick-disconnect model?
i am very confusing that which part i should use on my 1/2 promochill tube... and i need only two qdc.. there is too many types ;\
Water cooling systems, pc liquid cooling kit, cpu, video card, hard drive
Old October 15, 2011, 01:49 PM
Dazmode's Avatar
You must have teh same VL series for male and female parts. I.e. VL3N will fit other VL3N, but not fit VL3.
Also wantch for compression fitting part as they have both 5/8 and 3/4 OD versions.
Orange Build: Final Video
HTPC Build: Final Video
Old October 15, 2011, 02:19 PM
CTA's Avatar
CTA CTA is offline
so i must get two different (same model) parts? like 30cdn per a product?
honestly... i am not sure which to pick...
Old October 15, 2011, 02:38 PM
Dazmode's Avatar
one connection require two ends - male and female. If you want QDC on two tubes, you need 2 pairs. VL4N are most popular at the moment for 1/1-3/4 tubing, but really it does not matter that much imho.
Quick disconnect of tubing? magictorch Water Cooling 9 December 12, 2010 11:14 AM
[WTB] 5870 EK nickel plated acrylic model full cover water block (reference model) Lima Buy/Sell & Trade 4 October 4, 2010 10:33 AM
internet dosconnect ,connect,disconnect????? WolfBane Troubleshooting 8 June 28, 2009 04:47 PM
I could be a model mailaw Off Topic 15 April 27, 2009 11:08 PM
Acer Aspire 9300 Weird Wireless Disconnect Problem Constantine Troubleshooting 0 January 15, 2009 12:02 PM
