Old October 13, 2011, 05:23 PM
gingerbee's Avatar
not bad picked up a antec kuhler 920 and love it not as good as custom water but better then air and 80 bucks makes me happy when i am paying almost that for the air coolers i buy
Old October 14, 2011, 08:45 AM
ipaine's Avatar
Great review AkG, very well done. Although, and I think others would agree, I would like to see a few other non water cooling results to compare to. Mainly just the couple top end air coolers, just to see how these closed loop systems compare to them.
Originally Posted by Eluder View Post
I will say, Corsair's QC has been pretty poor as of late, but when their products work, they work really well.
I've been using the H100 for quite some time now, and it does a great job of cooling my rig, but I swear the fan controller doesn't work with my Gentle Typhoons, but haven't bothered to really check by trying the stock fans and see if all is well. Other than that, it's a solid cooler.
I am pleased with mine as well. I also have Gentle Typhoons on mine and it appears to me that the fan controller works well for me. I will say that I just want to get my hands on the Corsair link though so I can monitor everything better.
"Nothing sucks more than that moment during an argument when you realize you're wrong."
Old October 14, 2011, 08:47 AM
Soultribunal's Avatar
Hey Gingerbee,
Did they get the mounting system done better than Astek's original setup? I am curious to know if they mount easier or not.
AS for the cooler themselves, I love these Sealed WC systems now becuse I have no more worries on RAM clearance issues.
ST
www.realhardwarereviews.com
Old October 14, 2011, 09:28 AM
SKYMTL's Avatar
HardwareCanuck Review Editor
I swear, I must be seeing things:
Old October 14, 2011, 11:15 AM
So are you saying that you can tell that the fan speed changes when you push the fan controller button?
Are you using the AP-15's or another model of the GT's?
Old October 14, 2011, 05:51 PM
ipaine's Avatar
Ok, sure make me feel like a blind idiot.
Yes, there is very much a distinct difference between the three settings. Plus I could notice the temp differences at load.
Old January 21, 2012, 08:36 PM
Dwayne's Avatar
I looked through the review but did not see if the installation called for the fans to be pulling air into the case or pushing air through the rad and exhausting from the case. I am assuming that the fans are drawing air from inside the case and exhausting it out.
Dwayne's Rig - Asus Prime Z370-A : i7 8700k : Corsair Vengeance 32 GB DDR4-3000 : Corsair RM650x PSU : Corsair H100i V2: Fractal Design Meshify C : EVGA GTX 1080 :
HTPC - GigaByte H67MA-UD2H : i3 2100 : 8 GB Mushkin Silverline Stiletto : Antec TruPower 550W : : Corsair H100 : Sapphire HD 6670 : Corsair 650D: Kingston 60 GB SSD Boot
Tablet - Samsung Tab A 10.1"
Wife's Rig - MSI GL72M 7RDX
Old January 22, 2012, 06:35 PM
Silent_Avenger's Avatar
I believe corsair recommends that you have the unit pulling cold air from outside into the case through the rad. But for most people(myself included) just use it to blow air out of the case. The temp difference isn't huge unless you have bad airflow in your case.
Main System //// Dedicated Folding PC 1 //// Dedicated Folding PC 2 //// Laptop
Youtube Channel: http://www.youtube.com/DarkDivinityPC
I fold for a cure. Team 213366 and 54196.
  #19 (permalink)
Old January 22, 2012, 09:01 PM
Dwayne's Avatar
Thanks for the feedback SA. I'll probably set it up to exhaust then. I have the 650D and the front fan should pull in enough fresh air I think. I'll vent back and top and see how that goes.
  #20 (permalink)
Old January 22, 2012, 09:28 PM
AkG's Avatar
AkG AkG is offline
Hardware Canucks Reviewer
With water cooling units ALWAYS config them to exhaust (I dont care what the mfg'ers say...its just not an optimal choice to push hot air INTO a case). Doing otherwise negates one of the largest benefits of running water instead of air: COOL case temps. All that hot air inside a case is not a good thing. ;)
Corsair H60 High Performance Liquid CPU Cooler Review Comment Thread SKYMTL Water Cooling 40 April 9, 2012 07:25 PM
Corsair Hydro Series H80 Liquid CPU Cooler Review Comment Thread SKYMTL Water Cooling 5 October 6, 2011 08:05 PM
Corsair Hydro H70 CPU Cooler Review Comment Thread SKYMTL Water Cooling 64 January 26, 2011 03:21 PM
