Old February 22, 2008, 08:42 PM
Default Swiftech Apogee GT question
I just installed the Swiftech Apogee GT on my computer and the results are not impressive at all, is it possible that I'm not having a good connection with the CPU, or maybe something else????
I have a AMD Athlon 64 X2 4600 2.4Ghz, it's overclocked to 2.7Ghz, and with the Thermaltake Blue Orb at load I was getting 51C, now with the Apogee GT, it's only lowering the temp. to 49C. And at idle it's pretty much the same 31C
Thanks
AMD Phenon II X4 965 3.4Ghz
Motherboard: Asus M4A78-E
Memory: Kingston HyperX 4GB DDR2
Video Card: Nvidia 8800GT
Harddisk: 2 x Western digital
CD/DVD Drive: Asus
Monitor: LG Flatron W2353V
Case: Thermaltake Armor
Sound Card: Sound Blaster Audigy
PSU: Thermaltake TWV 500W
Software: Windows 7
Old February 22, 2008, 08:50 PM
3.0charlie's Avatar
What are the components and what is the loop you built? Do you have a pic?
Hydro-Quebec is salivating...
Old February 22, 2008, 08:53 PM
I started off with my with 1900xtx, which I got great results.
Here are all the parts:
http://www.hardwarecanucks.com/forum...tercooled.html
CD/DVD Drive: Asus
Software: Windows 7
Old February 23, 2008, 01:58 AM
sswilson's Avatar
Yeah, I'd definately try another mount of the WB.
Old February 23, 2008, 07:42 AM
3.0charlie's Avatar
Ok, you have some quality parts - but where you install the CPU block in the loop has a huge influence on temps.
Right now looks like you have: t-line - pump- rad - GPU - t-line. Where did you fit the CPU block in there?
Old February 23, 2008, 09:15 AM
lowfat's Avatar
Actually it really doesn't affect temperatures much at all. It is called thermal equilibrium. All the water in the entire loop is going to be within 1-2C of each other no matter where it is in the loop.
The Crippled God WIP
Queen of Dreams WIP
Big Lian Li
Complete
Forever Alone Complete
Old February 23, 2008, 09:29 AM
3.0charlie's Avatar
Except that you want your liquid to be as close as possible to the ambiant temp prior to hitting the CPU block, and that will happen right after the rad. It's called Thermodynamics.
Old February 23, 2008, 09:59 AM
Supergrover's Avatar
Did you "Bow" the GT? If so were the pins oriented the correct way?
R.I.P.
Old February 23, 2008, 03:43 PM
I triple checked the pins on the WB were in the right direction.
I have it going:
Pump-Rad-CPU-GPU-Pump
I'm going to remove it to make sure there is a good connection between the WB and CPU
Thanks guys.
CD/DVD Drive: Asus
Software: Windows 7
Bowing the Apogee GT Cptn Vortex Guides & How-to's 10 April 29, 2008 04:57 AM
Swiftech offering free backplate with apogee GT, GTX Babrbarossa Water Cooling 5 March 16, 2008 09:58 AM
Tec water chiller using Apogee gt's kirk_d Water Cooling 1 February 25, 2008 01:36 PM
Swiftech APOGEE Drive JD Water Cooling 14 August 16, 2007 10:35 PM
