Old October 3, 2011, 04:26 PM
Default H100 & Ultra Kaze
Hi All,
Do you think H100 will be able to handle ultra kaze if plugged in directly to the waterblock / controller?
I think ultra kaze draws max 7.2 w
Old October 3, 2011, 06:00 PM
I would say no.. but try it :P
Its not the watts you need to worry about its the amps.
Old October 3, 2011, 07:52 PM
KaptCrunch's Avatar
match or less then spec's fan on controlier use the chart to figure out your load
Old October 4, 2011, 07:43 AM
Thanks all for the input.. for sure ultra kaze doesn't match (or even less) than the fan that came in with the set.
Ultra kaze draws 0.6A, original fans 0.35A so almost double..
So I guess no eh? :(
Old October 4, 2011, 09:50 AM
AMC AMC is offline
They will draw too much. Especially since it draws power from the motherboard.
Old October 4, 2011, 09:30 PM
KaptCrunch's Avatar
mite work if using 1 Uk fan for H100 Fan Specification 120mm (x2) = 0.7a
H80 or H100 Reviews? PerryC Water Cooling 40 August 21, 2011 07:57 AM
Scythe 3000RPM Ultra Kaze Dead Things Air Cooling 16 February 1, 2011 12:10 AM
Ultra Kaze Fans in CM690 - Insane airflow!! mgroussel Air Cooling 8 December 7, 2009 11:11 PM
[FS] Thermalright 120 Extreme, Ultra Kaze 3000, Blue LED mhw100 Buy/Sell & Trade 14 May 19, 2009 03:49 PM
scythe ultra kaze are BAD for overvolting!!! solaris10 Water Cooling 1 February 1, 2008 11:14 AM
