Old September 29, 2011, 11:39 PM
Default Recall On Corsair H100
I was in a shop today, intent on buying an H100 (and some other gear). As my order was being pulled, an email came into the shop saying there is a recall on the H100s, by a specific batch/PIN....I didn't take that info down, but if you have one you might want to check with your store or with Corsair to see if your unit is affected. Anecdotally (that is, reading various fora) there have been reports of all sorts of failures. Some may well be user errors, but the reports include pump failures and fan controller failures.
The store had one or more cases of the H100's arrive today, all of there prior shelf inventory plus all of the new batch was included in the recall.
FYI.
Old September 30, 2011, 05:30 AM
BlueByte's Avatar
Thanks for the info, I have a H100 that has been working well but always good to check.
Old October 3, 2011, 04:27 PM
What was the problem? How do I know if say my unit is affected?
Old October 3, 2011, 04:29 PM
Perineum's Avatar
search the forums here, there is a link.
... but essentially your fan profiles don't work when using the profile button.
Old October 3, 2011, 04:57 PM
ipaine's Avatar
Check out the article here: Corsair Issues Warning of Possible H100 Fan Controller Issues | Hardware Canucks
All of the affected units come from batch #11359403 (see picture below showing where you can see the batch number) and so far, no other batches seem to be affected.
"Nothing sucks more than that moment during an argument when you realize you're wrong."
Old October 4, 2011, 07:50 AM
thanks for the info! Much appreciated! Now where did i put that box..
Originally Posted by ipaine View Post
Corsair H100 vs Corsair H80 Linus LinusTechTips Q&A 22 January 5, 2012 04:00 PM
Gentle Typhoon AP-15 or AP-29 or other for H100 ipaine Water Cooling 34 September 8, 2011 04:48 PM
H80 or H100 Reviews? PerryC Water Cooling 40 August 21, 2011 07:57 AM
Corsair Issues Force 3 SSD Recall Sam_Reynolds Press Releases & Tech News 9 June 8, 2011 06:28 AM
