Old February 21, 2008, 10:11 AM
Being a person that doesn't like Peanut Butter(I have a jar thats unopen ~6 years old) how thick do you spread it on toast/bread to make the "Traditional North American peanut butter sandwich" is it anything like making a cream cheese bagel *from timmies*
My core temps are around 40°c my room temps are around maybe 25°c or just a little higher. I can open my window and let my room get cold and i can drop around, 30-32°c. I'm using the Zalman 9700 and I use the the rice technique.
Old February 21, 2008, 05:57 PM
If you put as much cream cheese that my local timmies does, your board would look like it blew a load out the CPU slot.
I think by peanut butter method they mean cover the CPU entirely with a layer of paste you spread on with your finger, its generally only a mm or so thick. This is how I always did it, until someone showed me the ' right ' way.
CPU: E4500@3.3ghz ( 300X11@1.430v) MB: DFI LanParty ICFX3200 T2R/G
RAM: OCZ Platinum XTC rev2 ( 4-4-4-15 2t ) GPU: BFG 9800GTX
COOLING: Swiftech 120 Compact - Swiftech - MCW30 SOUND: HT omega Striker 7.1
CASE: NZXT Lexa Blackline PSU : OCZ Gamestream 700w
Old February 21, 2008, 07:10 PM
low351's Avatar
Keir's right "Peanut Butter" may be a bad name since someone might take it as meaning to liberally spread. I meant it as a comment on the consistency of the TIM not the amount. You still want as little thermal paste/grease as possible it's only meant to fill the natural deformities in the metal that cause air pockets and prevent full contact not as a dividing medium.
Old February 21, 2008, 07:20 PM
biff's Avatar
On a IHS like the C2D I use glob about half the size of a grain of rice and spread with a razor. It ends up less than the thickness of a sheet of paper, almost transparent. When the HSF is mounted I wiggle it a bit to make sure the TIM smushes out a little more. I haven't tried the method of letting it spread itself out or smearing with a finger and saran but I'm sure the differences would be minimal.
Q6600 @ 3.83GHz w/ D-Tek Fusion
Asus P5Q-PRO
2x 2GB PC8000 Mushkin Redlines @ 1020MHz w/5-5-5-12 timings
EVGA GTX 280 (SC?)
OCZ Gamer Xtreme 600W PSU
Cooler Master Cosmos on water
