Old September 24, 2011, 07:28 AM
Default New Rasa RayStorm CPU Block
RayStorm CPU WaterBlock (Intel) | XSPC
RayStorm CPU/APU WaterBlock (AMD) | XSPC
I was browsing around the net and stumbled upon this...
I really wonder how it performs compared to the other blocks.. =]
Old September 24, 2011, 08:47 AM
Wow that actually looks pretty nice, has that sleek look they always go for.
Cant wait to see some reviews on this.
Old September 24, 2011, 08:52 AM
lowfat's Avatar
XSPC Raystorm CPU Block Preview « martinsliquidlab.org
It looks to be one of the most nonrestrictive modern day blocks.
Old September 24, 2011, 12:49 PM
lowfat's Avatar
Yup. New king of low restriction.
Originally Posted by Martinm210
Not sure on the full review, work hours in my new job are really bad and long. I got the pressure drop testing done today though, so I can offer that up. I'll start working on the thermals as time permits..
New king of low restriction for 2011 generation CPU blocks...
Overclock.net - Overclocking.net - View Single Post - XSPC RayStorm: new cpu water block
Old September 24, 2011, 08:32 PM
mattlef's Avatar
I honestly love the look of this block. I hope it performs in like with the likes of the EK Supreme HF, and if so... I think i found my new block for this 2500K :D
My Rig:
Motivate TJ07
Check out my Build log!!!
Motivation: Sponsored by Galaxy
Upcoming Changes/Upgrades:
Check the build-log for more
Old September 25, 2011, 11:16 AM
lowfat's Avatar
I think it will also be one of my next water cooling purchases.
Old September 25, 2011, 05:50 PM
matari's Avatar
I really don't care for the design- might look ok for an alien build. As posted on other forums, I am worried about the mounting system. Sure it is simplistic, but how long will the acrylic last? What if I do not place the backplate on correctly? I have not used the rasa so maybe someone can answer those questions. I think the real selling point of the block will be it's price. If they can keep it under 70, then they will have a winner.
Old September 25, 2011, 06:03 PM
lowfat's Avatar
You really can't install the backplate incorrectly. Since the mounting bolts screw directly in to the backplate until they bottom out. Without the backplate, you can't mount it. The acrylic is also pretty thick on the Raystorm, plus it is reinforced w/ a piece of aluminum over top. Not sure if it is actually aluminum but it looks like it. I expect this block to sell for considerably more than the Rasa. More than likely will be comparable in price to blocks like the Supreme HF or CPU-370.
Old September 25, 2011, 06:24 PM
3.0charlie's Avatar
This 'metal' cover, if it's really 'metal' will bend from the 4 springs pressure. One of acrylic's physical property, is not to be used in a design where bending occurs. Micro-cracks will develop over time.
Old September 25, 2011, 07:12 PM
lowfat's Avatar
The acrylic does look pretty thick though.
Rasa block installation FATALDADDY Water Cooling 14 August 13, 2011 10:10 AM
Damn.. i am so lucky -_- (problem with rasa waterblock) Rush Water Cooling 5 April 26, 2011 04:35 AM
RASA 750 pump/res is rattling ? *updated* Rush Water Cooling 17 April 19, 2011 03:06 AM
Water block upgrade from XSPC RASA kit rugox Water Cooling 5 April 10, 2011 08:48 PM
Rasa 450 RS120 vs Rasa 750 RS240 Rush Water Cooling 8 March 29, 2011 10:28 AM
