  #21 (permalink)
Old February 19, 2008, 06:18 PM
NoL NoL is offline
Well budget SS that can handle a quad I've done and done and am now selling sorta like hotcakes, same thing UnG posted in the hot deals section. Waterchiller, how does small, decently quiet, decently low power, decent quad able and maybe quad plus gpu performance sound, and best yet, semi adjustable temperature range?
  #22 (permalink)
Old February 19, 2008, 06:28 PM
3.0charlie's Avatar
You've hit the nail on the waterchiller. CPU-only WC setup on the Quad, mainly a folder.
Hydro-Quebec is salivating...
  #23 (permalink)
Old February 19, 2008, 07:47 PM
NoL NoL is offline
Why a chiller vs a direct die system?
  #24 (permalink)
Old February 19, 2008, 08:05 PM
3.0charlie's Avatar
First I would like to experiment with a waterchiller - simple addition to the existing loop. But one day I would like to bench using a single stage - nothing glamorous, nothing fancy. Just have some fun and play with it.
  #25 (permalink)
Old February 19, 2008, 08:22 PM
NoL NoL is offline
You'd have to insulate your waterloop then you know.
  #26 (permalink)
Old February 19, 2008, 08:30 PM
3.0charlie's Avatar
Do you have pics of a chiller? I taught that I could cool the liquid before reaching the block.
  #27 (permalink)
Old February 19, 2008, 08:33 PM
Prof. Dr. Silver's Avatar
Not knowing nothing about H2O cooling but kind of grasping the big pic......Would a chiller be the same as dumping your rad in a bucket of icewater? So what would insulating your tubes do? I assume only the 'cold' ones that lead to the CPU/GPU right?
Hardcore Folding at it's BEST! HWC - TPU.... There can be only one team in front! TPU, can you smell our *sses already?
  #28 (permalink)
Old February 19, 2008, 08:41 PM
biff's Avatar
The liquid would be below ambient temps and prone to condensation. Unless the flowrate is very slow in the system there will be a minimal temp difference between the fluid entering and exiting the CPU block so the whole fluid system would need insulating. At least with direct die only the CPU socket needs to be insulated.
i7 4790K @ 4.8GHz w/EK Supremacy Evo
MSI z97 Gaming 5
2x 8GB Gskill Sniper 2133 @ 2400MHz
EVGA GTX 280 (SC?)
OCZ Gamer Xtreme 600W PSU
Still rockin' the Cooler Master Cosmos on water
  #29 (permalink)
Old February 20, 2008, 06:11 AM
NoL NoL is offline
Basically yes, but a good chiller can provide more overall system performance if your willing to insulate more.
Possible new sub section vintank Suggestions & Feedback 1 December 27, 2007 02:56 PM
DC section qwerty Suggestions & Feedback 6 December 9, 2007 10:35 AM
New Section ineedaname Suggestions & Feedback 0 December 4, 2007 07:52 AM
What about a vendor section? qwerty Suggestions & Feedback 1 December 1, 2007 09:36 PM
