Old September 14, 2011, 03:12 PM
PerryC's Avatar
Any recommendations for a tube reservoir?
The oath to serve your country did not include a contract for normal luxury, and comforts enjoyed within our society. On the contrary it implies hardships, loyalty and devotion to duty, regardless of rank
Old September 14, 2011, 09:26 PM
AmuseMe's Avatar
If you can find an IandH Stealth res, then that's the one! Or an old original EK MULTIOPTION
Old September 14, 2011, 10:02 PM
lowfat's Avatar
I'd take a Koolance 80mm tube reservoir and base over either of those anyway. They are so huge it looks awesome.
The Crippled God WIP
Queen of Dreams WIP
Big Lian Li
Complete
Forever Alone Complete
Old September 16, 2011, 09:19 PM
Dazmode's Avatar
Originally Posted by lowfat View Post
The controller is only useful for the D5 'Strong' models that can run @ 24V. If you don't use them, then the controller is pretty much useless. The bay reservoirs are for space saving and looks. The Koolance ones are especially hard to bleed. If you have room for a good tube reservoir then I'd go that route if you can.
Actually D5 Vario we are getting are also can run at 8-24v as Strong pump, but only at max 1.42A, while Strong rated 1.7A.
I'm not sure if anybody tested if there are any gains for running D5 Vario at 24v. ??
Orange Build: Final Video
HTPC Build: Final Video
Old September 16, 2011, 09:28 PM
lowfat's Avatar
Originally Posted by Martin
Unfortunately there is not much benefit to using 24V on the PMP-450 pump. Up to about 1.5GPM there really was no measurable benefit, on the contrary because it was consuming about 1-2 watts more. I would not recommend purchasing a controller to operate this pump beyond 12V, it’s just not enough difference to bother with.
Koolance PMP-450 (D5 Vario) Pump martinsliquidlab.org
Queen of Dreams WIP
Big Lian Li
Complete
Old September 16, 2011, 09:33 PM
Dazmode's Avatar
Cool, thanks for update! I'm totally out of cycles to read anything....
[Review] Koolance CPU-360 Dazmode Water Cooling 2 May 31, 2010 05:43 AM
[FS] koolance 4870x2 wb $60 - tripple rad, and lots of fans. + bunch of wc stuff CHEAP. kyle_L Buy/Sell & Trade 9 June 29, 2009 12:10 AM
[FS] New Zalman fans, used Scythe and blue LED fans mhw100 Buy/Sell & Trade 15 June 22, 2009 02:32 PM
WTB: Koolance VID-398GX2 Dead Things Buy/Sell & Trade 5 October 28, 2008 01:31 PM
