  #21 (permalink)
Old September 19, 2011, 08:15 PM
Dazmode's Avatar
Sunbeam is one of my long time favorites, having said that sometimes nice to see RPM reading too :)
Orange Build: Final Video
HTPC Build: Final Video
  #22 (permalink)
Old September 20, 2011, 06:09 PM
Amarthfea's Avatar
i actually just picked up a sunbeam from daz (big shout to daz!) and am really pleased with it so far, and for the price i'm really pleased with the watts per channel (which to me matters most watts per chanel / $) at 30 watts per channel you'll have no problem putting multiple fans per channel
as for d series heat. I've had my d5 running all summer even when it was 30 degrees in my room, its never more than warm to the touch.
~Elysium, I behold your beauty...
  #23 (permalink)
Old September 21, 2011, 02:19 PM
Keltron 3030's Avatar
I'd like to get opinions from other owners of the noted pumps (D5 and DDC-3.25).
Again, I would like to expand this in the future to add at least a gpu (which I hope to have by the summer) and MAYBE (!!!) a mobo block (again, this comes with an upgrade, and this one depends on whether i really need it or not, but the option to have it is good none the less)
Thanks in advance guys!
FFFFFFFUUUUUUUUUUUU-
  #24 (permalink)
Old September 21, 2011, 04:02 PM
AmuseMe's Avatar
I've owned both. That is, the variable Swiftech MCP-655 and the Swiftech 3.2 - I like the DDC's more. They are small and efficient. Also, they come in handy the more restrictive your loop gets. I'd say use one 350/355, and if you make those upgrades (GPU mobo etc.) throw in another :)
help deciding which GPU to get? bushwickbill Video Cards 6 April 10, 2011 11:42 AM
Help deciding which pump BrokenHalo83 Water Cooling 7 October 27, 2009 10:20 PM
Need Help deciding PS3 or Xbox 360 AA93 Gaming 39 May 15, 2009 12:47 PM
I need help deciding. encorp CPU's and Motherboards 16 March 13, 2009 12:07 AM
Deciding on a Case BALISTX Cases 6 May 19, 2007 09:55 AM
