Old September 11, 2011, 01:42 PM
Default My first effort at water cooling...
Just finished my first water cooled build. Quite pleased. Photos to come.
Tell you what - wish I'd used a reservoir. Has taken hours to get the air out with this T-line. Not an expert though ... so may have not done something quite right. Also, frustratingly, I got the 'in' and 'out' the wrong way on the CPU block. But I checked and it seems the RASA has an even pattern flow through the block, so I can't see it will hurt. I've checked temps and it's 46 on idle and 68 on 100% on all cores for an hour. Just a little more head room than the H50!
Specs
CPU: i7 930 @ 3.8 (for 24/7 usage) with XSPC RASA block. Mobo: P6X58D-E. GPU: XFX 5870 v2 with EK waterblock. RAM: 6GB DDR3 G. Skill. HD: 128 GB Crucial C300 SSD & 750 Hitachi. RADS: 2x240 XSPC RS (with some random fans I plan to change!).MCP355 18W pump. TX850 Corsair PSU.
Old September 11, 2011, 01:43 PM
Old September 11, 2011, 01:44 PM
Old September 11, 2011, 02:17 PM
supaflyx3's Avatar
way to much tubing for my tastes, but nonetheless good job :)
Old September 11, 2011, 07:12 PM
Amarthfea's Avatar
I like it, but where are the two tubes going to? looks like they would be going to a bay reservoir but you have a tee line?
still i like the blue and white, classy
~Elysium, I behold your beauty...
Old September 11, 2011, 07:39 PM
Looks good for a first time effort at watercooling.
Old September 11, 2011, 07:44 PM
PerryC's Avatar
I think he has them going to his second rad, not sure though. His specs in the first post show 2 x 240 rads, but I only see the one in the pics. Not sure what case that is, so I don't know if the case would have the ability to mount a rad up top.
The oath to serve your country did not include a contract for normal luxury, and comforts enjoyed within our society. On the contrary it implies hardships, loyalty and devotion to duty, regardless of rank
Old September 11, 2011, 08:05 PM
Supergrover's Avatar
Yeah you can see the rad in the back corner first image.
Why no rear fan though? Still going to help pull heat off the board.
R.I.P.
Old September 11, 2011, 11:34 PM
Hi guys,
Thanks for the feedback. The second Rad is at the top. It's a coolermaster 690II Advanced case.
RE the amount of tubing - I did try to minimise lengths. The only areas to have excessive length are- top rad to CPU, as I had to go around the RAM cooler, and the T-Line, which I have left long just for ease of use.
But it's 1/2 ID tube - and now I wish I'd gone for 3/8 as it certainly does look tube heavy!
Next little project is to put in a side window, which shouldn't be to hard.
Cheers for the feedback all!
Old September 12, 2011, 12:26 AM
You'll get the hoses down after a couple of builds but 1/2 is a PITA doing tight loops add in comp fittings and yeah can get frustrating when the tube dont want to go right, I just go have a smoke and relax come back in a few.
What side window? A square? Fan mounting? I used to like doing side window mods before cases all started coming with windows.
Funny now that they do, I use a windowless case. :)
R.I.P.
New To Water Cooling mjbdc07 Water Cooling 10 August 31, 2010 05:25 AM
HAF 932 Water Cooling miggs78 Water Cooling 7 January 3, 2010 12:17 PM
Water Cooling Kit AmuseMe Water Cooling 9 July 12, 2009 11:11 AM
Water Cooling How To?? e_1337 Water Cooling 5 March 16, 2008 01:00 PM
