Old February 17, 2008, 01:46 PM
Cptn Vortex's Avatar
I am using the Scythe Slipstream fans on a Swiftec MCR220, and they work great. Better than the Loons they replaced. The only thing I don't like about them are they are made out of very thin and weak plastic. Tightening down the screws really bend them.
I really really wish I could get some nice quick-connect barbs.....I literally pulled a bunch of skin from my thumb yesterday taking tubing on and off barbs. You should have seen the size of blister I got! NEASTY!
Have fun with your build! I re-did mine and it looks quite rad.....leak testing now....
The Vortex H20
MSI Z87-G45 Gaming
i5 4690K @ 4.5GHZ
SLI GTX 1070
12GB GSkill Ripjaws X 2133MHZ CL10
OCZ Z-Series GOLD 850W
HP OMEN 32 1440p 75hz
Benq W1070 Pojector.
Watercooling:
Old February 17, 2008, 02:53 PM
Moneyless's Avatar
I just finished my w/c setup yesterday... ^_^
Another thing you can do which helps fit the 7/16" tubing on 1/2" barbs (especially on the D5, that was a real PITA...) is rub a minute amount of Vaseline on the barbs.
"I hate broccoli
And think it totally sucks
Why is it not meat?"
-Deadpool
Old February 18, 2008, 05:21 PM
CanadaRox's Avatar
I found dipping the 7/16" tubing ends into hot water (boiling water actually) made it extremely easy. Gotta make sure its clamped on tight though, because the tubing stretches a lot and isn't as tight of a fit.
Project: Black and White
Old February 18, 2008, 05:35 PM
3.0charlie's Avatar
To an extent - any material when cooled will contract and fit properly againt the barb. Hot water is enough, no need for boiling water.
Hydro-Quebec is salivating...
Water Cooling How To?? e_1337 Water Cooling 5 March 16, 2008 01:00 PM
Ram Water Cooling loop Shredder Water Cooling 5 January 24, 2008 09:55 PM
Water cooling kit Vinnie Water Cooling 5 November 12, 2007 10:22 PM
Water cooling build SHaCK Water Cooling 34 April 24, 2007 07:45 AM
Another DIY Water Cooling Rig Magnesious Water Cooling 5 April 14, 2007 11:51 AM
