Old September 5, 2011, 02:06 PM
Default SLI 580 question
So I have a normal 580 with a EK waterblock. I picked up a Direct Cu ii 580 that would use a modified water block that EK sells. I wanted to add it to my loop. Does anyone know if this will work? to connect them?
K - Dual VID Connector, Adjustable 2-3 Slot Spacing BLACK K - Dual VID Connector, Adjustable 2-3 Slot Spacing BLACK [CNT-VDA34-BK] - $15.99 : DazMode, The Best Canadian PC Watercooling and Modding Store!
Old September 5, 2011, 05:31 PM
KaptCrunch's Avatar
just GPU or with CPU in loop
Old September 5, 2011, 05:48 PM
GPU's only, 360 rad.
Old September 5, 2011, 07:17 PM
I think you need to worry if the blocks line up to be able to use that connector, otherwise I think it should work.
Old September 5, 2011, 08:34 PM
Yah, that is what I am trying to figure out.
Old September 5, 2011, 08:39 PM
SugarJ's Avatar
Gotta contact EK, or ask Daz to do it.
Old September 6, 2011, 10:04 PM
Dazmode's Avatar
I don't think anybody tested this so far. If cards are in slots that next to each other it may be a problem. I cannot say if they align or not by looking at non-installed blocks.
Orange Build: Final Video
HTPC Build: Final Video
Old September 6, 2011, 10:22 PM
KaptCrunch's Avatar
can use a "D" plug to get right spacing with compression fitting
Old September 7, 2011, 03:38 PM
I ordered it anyways from Daz. I guess I will figure out if they fit when they come :) There is two spaces in between them just not sure if they would line up. We will see.
Old September 7, 2011, 04:32 PM
lowfat's Avatar
I have been told that all recent EK blocks inlet/outlets should lineup. So hopefully you shouldn't have a problem.
Mael
Big Lian Li
Forever Alone
