Old September 8, 2011, 06:54 PM
PerryC's Avatar
Bulldozer server chips just shipped, but the mainstream ones likely just got delayed again...
edit: I like the way you have the rad bottom mounted.
The oath to serve your country did not include a contract for normal luxury, and comforts enjoyed within our society. On the contrary it implies hardships, loyalty and devotion to duty, regardless of rank
Old April 7, 2012, 04:38 PM
nasrott's Avatar
ya hit my back outlet fan with my fingers broke a few blades off the fan, freaked me out for a sec or two, dropped a 140 mm noctua in there to replace it.
Old November 8, 2012, 07:42 AM
Trial Member
Question, with the rad ports and pump at the highest points in the reservoir/system wouldn't the pump/copper plate area run dry? There is inevitably air in the system.
Old November 9, 2012, 03:45 PM
KaptCrunch's Avatar
Lotus77 if the loop is 100% filled it wouldn't mattter
if were me i'd filp the cpu so that hoses are on top
and take rad to the back side of case with hose on bottom
an mount with stand off's on rad higher then pump
doing this set-up will tweak the most out of cooling
and pre-vent pump starvatiion
Tags
kuhler , level10gt , watercooling
Antec Kuhler 620 vs Corsair H60 Thread slippy Water Cooling 5 March 11, 2011 09:04 AM
Thermaltake Announces Immediate Availability of Level 10 GT FiXT Press Releases & Tech News 24 February 12, 2011 01:58 PM
Thermaltake Level 10 and Megahalem Closed Note New Builds 12 August 8, 2010 12:10 PM
Thermaltake Level 10 Signal2Noise Cases 2 September 29, 2009 10:15 AM
Thermaltake Level 10 chassis Mark Press Releases & Tech News 18 September 28, 2009 01:51 PM
