View Poll Results: How did I do
I'm envious! 1 16.67%
You did good, some could be better. 5 83.33%
It needs a lot of work... 0 0%
Voters: 6. You may not vote on this poll
Old August 26, 2011, 06:48 PM
AmuseMe's Avatar
Swiftech MCP355 Watercooling High Performance Pump Equivalent to Laing DDC 12 volt DC Pump and EK Waterblocks EK-DDC X-Top Rev 2 - Acetal
Though the one you posted in ideally the same thing.
Yea... Res>pump :p
Old August 26, 2011, 10:51 PM
Dazmode's Avatar
I wasn't impressed with Ximatech fans in my last build. I'd rather put YL, Koolance or GT on radiators.
Orange Build: Final Video
HTPC Build: Final Video
Old August 27, 2011, 01:21 AM
I recognize your name, do I know you from somewhere? Anyways, what was the issue with the fans? I was going to get Delta 5200 RPM's on a BIX rad, but someone said this would perform equivilent and quieter. But YL's seem quite cheep to be good quality, GT's are quite expensive and have less CFM and I havent really looked at Koolance. What about Scythe Ultra Kaze? those are pretty cheap??? Thanks so much for the input btw!
Oh and one thing, I understand it should be rad>pump but isnt the rad supposed to be the highest and pump the lowest in the build? My config would make more sense if that is so? Thanks
Old August 27, 2011, 05:37 AM
AmuseMe's Avatar
You mean RES?
Old August 27, 2011, 12:02 PM
I giggled a bit.
Tags
build , overclocking , system , watercooling
[FS] Trackpoint tips elninio Buy/Sell & Trade 0 February 10, 2011 04:10 PM
Pro Tips For DIY Repair bissa Off Topic 0 January 10, 2010 11:43 AM
OC tips Wurmer Overclocking, Tweaking and Benchmarking 3 August 11, 2009 06:33 PM
Got any i7 OC tips? Babrbarossa Overclocking, Tweaking and Benchmarking 7 April 13, 2009 12:44 PM
Hi, new to O/Cing want some tips Gooses Overclocking, Tweaking and Benchmarking 14 September 3, 2008 08:39 PM
